Question about Itronix GoBook Q200 Pocket PC
Os image not found
Q2boot 2.52 os image not found image boot failed
Boot image signature fail How do I update it
Start up with your OS disc and repair the boot manager.
Sep 12, 2014 | Computers & Internet
Pxe rom boot
For PXE to work you need to enable boot from LAN this will then take you to your image server where you then deploy it. when it says no OS it means that it has gone through or skipped PXE.
when we switched to imaging with PXE we had trouble with a certain type of PC and to solve it we updated the BIOS
Jan 15, 2014 | Dell Inspiron 14R (N4010) and 17R (N1710)...
Booting problen
first off does it come up with any error messages like no MBR found or no HDD found
if so install Knoppix cd or dvd version to a disk or a usb.
if you are unsure how to install knoppix to disk download universal usb installer and select the knoppix iso image.
once you've done that go into the bios and change the first boot device to either the CD/DVD or USB if it boots from either than your PC is fine you will need to reinstall the OS or replace HDD.
if you can see HDD in knoppix there is no reason to Replace HDD
if you cant boot to either of these try taking one stick of ram out and swap them between dimm slots
Dec 16, 2013 | Compaq Evo D31vm Pd1092 Pc - No OS -...
My phone wount power on and instead makes a beep. what could be wrong?
The beep is the boot loader. Which means that either the operating system cannot be found, or its kernel is is corrupt. This can be either from having a defective memory chip (rare, unless you left it in the sun, microwave or next to something radioactive ;), or a system/OS update that went badly wrong.
Usually, it's the latter.
If you are lucky, your boot loader can go to a special mode, where it can still boot up enough to load a new OS image. Usually by holding some special key combination or something while it boots up. But you have to look this up yourself, as it's very different for each line of devices.
And last but not least, see if it still happens if you replace any battery, memory card, SIM card, or anything else that's replaceable. (You could borrow them from a friend. It's just for one minute, after all. :)
If all of that fails, your only chance is to go to your mobile phone shop, and see if they can fix it right there or send it in. Let's hope it's not that bad. :)
Aug 22, 2013 | Motorola Mobility Moto Q
Can not find os
Download the OS from the Alesis website, write it to a CD as an ISO image, put the CD in the Alesis, and follow prompt to load the OS
Aug 22, 2012 | Alesis MasterLink ML-9600
Toshiba sattelite A205 s5816 will not boot up. Auto fix failed, restore failed , error could not find path. Results from diagnosis -Error=0x0. root cause found = No OS files found on disk
windows are dead. reinstall the Os. if you have important data - remove the HDD, copy all inportand files, put it back in and then reinstall the system
Mar 09, 2012 | Computers & Internet
Operation system not found
Hi and Welcome to Fixya
THis means that the operating system of this computer is already corrupted especially the boot manager. This is the file the requires your computer to boot up to windows. You can still use the computer but you need to reinstall the operating system again by using the recovery disk of the computer.
Thank you for using Fixya!
Feb 22, 2011 | Sony VAIO Notebook
My laptop does not work it says PXE-E61:Media
Put 'Hard Drive C:' before 'Network' in the boot order
(If the hard drive does not appear in the boot order, that's why the PXE network boot agents start)
Note : Check that the hard drive is seen in the BIOS setup
Cause:
PXE (pronounce Pixie) is an agent used to boot on to the network
It's using the DHCP protocol to localise a server where the image of the OS is located
In order to PXE boot press F12 at startup or configure the boot order in BIOS to display 'Network' before 'Hard Drive C:'
If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
That is caused by the hard drive is missing, unplugged or failed
Jan 11, 2011 | Acer TravelMate 4062LCi Laptop Charger...
Acronis loader fatal error- I can't boot up !
if your pc starts ok with no cd in than do it like that if you see this error all the time it means your hard drive is shot, or erased, or partially erased and needs to be setup again or replaced. got nothing to do with acronis if it does this all the time even with no cd in drive.
Aug 23, 2009 | Acronis TRUE IMAGE HOME 2009 for PC
Os not found
Operating system not found indicates that the system is not seeing a bootable device. Possible causes are:
1. Hard drive not detected due to loose connection. Reseat the HDD.
2. Hard Drive is failing/Failed. Replace HDD
3. System has a floppy drive and a diskette in the drive, remove diskette, reboot
4. Hard drive not in boot sequence. Reset BIOS to defaults
Jun 22, 2008 | Acer Aspire 5050-3242 Notebook
Itronix GoBook Q200 Pocket PC Logo
24 people viewed this question
Top Itronix Computers & Internet Experts
Steven Wander
Steven Wander
Larry Chandler
justwinwin
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
