Question about E-Machines eMachines Desktop PC
How do you fix an e-machine faulty power supply on e machines and what does a power supply cost?
  • 57 Answers
Here is a step by step diagram showing how to remove/instrall an ATX Power Supply with pictures included:
http://www.fonerbooks.com/r_power.htm
Posted on Jun 15, 2009
Pentax wont switch on without power supply
Since the machine only work with adapter the power supply IC inside is faulty. if you can NOT fix it. Go to the repair shop for fix it.
Aug 02, 2012 | Cameras
The machine doesnt work at all.the LCD screen shows the first 8 digits black and the other 8 blank.Can you help me?
This is a well known fault with fax machines and unfortunately the main board and or the power supply has gone faulty. there is no fix other than to replace them. Its probably not cost effective. look for a replacement machine.
Sorry!
Sep 29, 2011 | Samsung SF-515 Plain Paper Laser Fax
No power Samsung WA8Ou3 washing machine
Possible that the main controller board is faulty if there is power supply to the unit. You can use a multimeter to check this out to confirm. Sometimes the power supply to the board can be faulty resulting in total failure of the board.
Feb 25, 2011 | Samsung Washing Machines
I have a miele excella series g2670sc that says "no water intake". We cleaned the filters (not dirty) but it still says the same thing. We live outside the parameters of normal travel for the...
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is betting to the valve, the timer might ba faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
Feb 22, 2011 | Miele G2670SCSF Dishwasher
I HAVE A CANON IR 3300 MACHINE I HAVE ERROR E00000-000
WHAT: Either the main thermistor doesn't attain 30?C 1 second after the power switch is activated or it doesn't attain 70?C 2 seconds thereafter.
WHY: It has a faulty fixing film unit, lack of connectivity with the main thermistor, lack of connectivity with the fixing heater, a faulty main power supply PCB, or the DC controller PCB is faulty.
NOTE: You can reset the error by performing the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
CONNECTOR FIX: Make sure that the connector of the fixing assembly is seated.
A. main power supply PCB (J8) relay connector heater
B. DC controller PCB (J320) relay connector thermistor
FIXING FILM UNIT (THERMISTOR) FIX: With a multimeter, check the interval between pin 1 & pin 2 & between pin 3 & pin 4 of the connector (4-pin) of the thermistor for electrical continuity. A result of ?? means that the circuit is open (lack of connectivity). Resolve this by replacing the fixing film unit.
MAIN POWER SUPPLY PCB, DC CONTROLLER PCB FIX: Press the Start key. If the drive voltage of the heater is supplied by the connector J8 of the main power supply PCB, then the main power supply PCB should be replaced. If not, then the thermistor control mechanism is faulty & the DC controller PCB should be replaced. Use the following to ascertain this:
Main heater: between J8-1 (FSR1) & J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) & J8-5 (FSR COM)
Sep 25, 2010 | Office Equipment & Supplies
Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply: Do you have to use a emachine power supply...
No it is not neccassary to use a E-machine power supply if your previous one has become faulty. You can use any one as long as it has the required power rating.
May 18, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
I have power to the machine, but it's not heating up. Is this a problem that can be fixed?
it can be fixed depending on problem and cost possible causes could be faulty thermostat fusible link blown heater blown or faulty wiring any of these could cause your problem you may have to have it servised letme know the outcome
Nov 12, 2009 | Gaggia 102534 Espresso-Color...
Ariston washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Nov 17, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Washing machine
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Power Surge and WD16BA
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
E-Machines eMachines Desktop PC Logo
53 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
