Question about CHOICEMMED Pulse Oximeter Oxywatch MD300C631
My pulse oximeter read 7 error. How do I fix it?
My pulse oximeter modelC20 read 7 error How do I fix it? Regards, Francisca Petersen Franpe66@yahoo.com
What is Err 7 on the medline Finger SAT Pulse Oximeter
Error7" displayed on screen Error 7 means the emission LED or reception dioxide is damaged. Check the emission LED and reception dioxide.
Jul 22, 2015 | Medline Onepiece FingerSAT Oximeter
I received a defective Pulse Oximeter
Did you check with the manufactorer? Most of the time they will exchange it for you.
Sep 10, 2014 | Contec Finger Pulse Oximeter CMS50-DL
What does a pulse oximeter measure?
the pulse oximeter measures the oxygen saturation of your blood without having to take a blood sample
Jan 30, 2013 | Health & Beauty
What exactly is a pulse oximeter?
A pulse oximeter is a medical device that indirectly monitors the oxygen saturation of a patient's blood (as opposed to measuring oxygen saturation directly through a blood sample) and changes in blood volume in the skin, producing a photoplethysmogram.
My mother has a Digit Pulse Oxymeter and I was wondering how one knows if the %oxygen is reading correctly. Lately all her readings are always 97%. Very little variation.
The normal oxygen saturation in the body read by the any pulse oximeter whether it is portable or built in type is 95%-100%. If ***********'s oxygen reading as you have said is 97% definitely it is within the normal range. You can also check and make sure that your oximeter is working by placing the oximeter to your finger. If the pulse read by the oximeter is the same with your heartbeat it means that is working alright and the oxygen reading would fall between 95-100%. I hope my answers will help you.
Aug 26, 2010 | Probasics Digit-Ox Finger Pulse Oximeter
I need a Battery SPO Medical 903036 Mate Pulse
I am doing the same thing. Found the 903036 on Amazon, and scrolled down to "Frequently Bought Together" and found a lithium battery. Am thinking that is the one. http://www.amazon.com/SPO-Medical-903036-Check-Oximeter/dp/B000BQKH9W
Oct 08, 2009 | NRS SPO Medical 903036 Check Mate Pulse...
While connected it says "please check connection and try again"
A few things could be going on.
First the unit
1. Remove and replace the battery to "reset" the unit.
2. If the batteries are old, they might need replaced.
3. If it has been used and is dirty, clean the sensors.
Second the finger
1. If there is poor circulation from: low heart rate, poor circulation, or cold fingers, the unit will have difficulty.
2. Dark pigmented skin can cause errors.
3. Fingernail polish will cause errors.
Here is some more info for your finger oximeter
Sep 27, 2009 | NRS SPO Medical 903036 Check Mate Pulse...
No reading for the blood oxygen level
OK - I had the exact same problem. I cleaned the inside of the oximeter with a cotton swab and denatured alcohol. Then tried it. It did not work. Darn. But I tried it an hour later, and suddenly, it started to work perfectly. I do not know what went wrong, and why it did not work immediately after cleaning. Maybe it was still damp from the alcohol? Unlikely, but I cannot figure out anything else. Anyway, try that and see if it solves the problem for you, and if the oximeter does not work for the first hour or so after cleaning, don't give up on it. Good luck.
Feb 05, 2009 | NRS SPO Medical 903036 Check Mate Pulse...
CHOICEMMED Pulse Oximeter Oxywatch MD300C631 Logo
99 people viewed this question
Top CHOICEMMED Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a CHOICEMMED Health and Beauty Expert? Answer questions, earn points and help others
