At first I noticed all I was getting was black ink and no color.Then nothing.
I can hear the printer making the sounds like it does when it prints, but nothing shows on the paper. There is a mountain shaped puddle of black ink under the black cartridge, and the printer doesn't seem to acknowledge the color cartridge, and the toolbox says I can't calibrate the color because
"The service you have chosen is not applicable for your current configuration." I can also see a spray of ink on the inside of the door.
As far as I can remember , I haven't changed any settings.
I tried a complete uninstall and reinstall with no change.
SOURCE: Cannot see ink levels
Inkjet printers do not detect ink levels period. An estimate of level is made by the software. It calculates the volume of ink that was dispensed during printing pixel by pixel. If you re-install the software the tally is lost. If you want to convince the software that the cartridges are full then go though the procedure of renewing the cartriges but put the old ones back in. If I were you, I'd completely ignore the displayed levels of ink, its worthless technocrap. Your eyes are the best judge of whether the cartridges need replacing or not when you look at your prints.
SOURCE: HP PSC 1315 - Won't print
cleaning the rubber feed rollers with WD-40 sprayed on a cotton rag seems to be working on my HP 1510PSC.
SOURCE: Printer Toolbox Not Recognizing New Black Ink Cartridge
Pop out the cartridge and look inside the printer where the black cartridge goes. There may be punctures in the ribbon cable from the metal wire that rests against the catridge. I have lost 2 6940's to this problem.
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the
printing problem..
# Hold the cartridge upside down, with the
bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the
cartridge on the bottom (where the ink comes out). Wipe the printhead
horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure
the ink is flowing.
# Next, look inside the printer and locate the
carrier that holds ink cartridges. Caution: Make sure the cartridges are not
installed at this point.
1. Look for a shiny piece of metal underneath the
contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and
wipe along the bottom of the shiny metal piece. Note: You may need more than
one swab.
# Reinstall the cartridges, making sure you snap
them correctly into the printer.
Hope this help. Please
Rate My Response! Thanks!
SOURCE: Just replaced the black ink cartridge on the HP
Take a look at my tip on cartridges it may save you a lot of time and money
http://www.fixya.com/support/r3845491-ink_cartridge
OR
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Hope this gives you the information you need
Bob
EXMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
