Question about Nordic Track GX 4.5 Cycle
Can not reduce resistance on my nordic track gx 4.5 cycle
It's set on high, and won't reduce resistance
maxtreadmill
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
maxtreadmill
  • 832 Answers
SOURCE: nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Posted on Jun 14, 2010
  • 218 Answers
SOURCE: how do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
Posted on Aug 11, 2010
ercupa190
  • 12223 Answers
SOURCE: BUYER BEWARE!! I purchased
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check too:Optical Sensor. If have it
Posted on Nov 08, 2011
ercupa190
  • 12223 Answers
SOURCE: Nordic Track X5 belt won't move
1) Lube the deck belt, this happen because the electronic system protect the system and shut down.the cause is deck worn.
2) Lube the rollers bearing too.
3) Measure the input voltage motor, if there are the motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
God bless you
Posted on Jun 13, 2012
Thermal Breaking Window
something wrong with this advertisement
proof is , heat up a piece of aluminium and see how long and how close your hand is to the heated section before you get burnt
then wrap a piece of fiberglass around the aluminium and heat it and see you get burnt at all
aluminium is used in all radiator fins for the heat transfer properties
Dec 22, 2016 | The Watches
Pedals on my NordicTrack gx 4.5 slip, and tension will set to harder, but even on setting 1, it feels like 4-5. The belt is tight. We usually used setting 2 or 3.
Try to lubricate the treadmill belt after tenstioning. Check the vidoe to know how to lubricate the treadmill.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Treadmill walking belt lubrication
Dec 19, 2016 | Nordic Track Exercise & Fitness
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Panel is flashing
Hi Ines, for more information about your question please visit the website below. Good luck and have a nice day.
http://c.shld.net/assets/own/spin_prod_670268901.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 25, 2015 | Nordic Track NordicTrack GX 5.0 Pro...
Why can we only peddle backwards. When we peddle forward, there is too much resistance.
Your resistance motor can be bad, the magnets are full expanded and stopping the forward movement.. You need a crank remover to take the body covers off to inspect the resistance motor.
Mar 01, 2015 | Nordic Track NordicTrack - GX 2.5
Replaced throttle body, now have reduced acceleration. Does idle need to be re-programmed? Will it re-set on its own?
That code is for Second down stream oxygen sensor heater resistance, heater current requirements too low or too high (bank2)
Feb 28, 2015 | 2005 Ford Five Hundred
How to remove crank arms from nordictrack gx 4.2
most bicycle shops have a tool called a sprocket remover. you remove the nut.it threads in the hole then you turn the handle to remove.
Aug 26, 2014 | Nordic Track NordicTrack - GX 4.2 Pro
Nordic Track GX 4.5 Cycle Logo
126 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
