Question about Oreck Cord Free Electric Broom Quick Stick Vacuum Cleaner
Type of charger cord free broom takes
What type charger does quick stick use? how many amps or mil amps
Do disposable pads stick to plastic mop head, or onto mop?
  • If you are taking about a dust mop it goes on the connection to the rod if its a wet mop like shark or quick brooms it goes on the mops head.You will see 4 holes on the corners of the mop.Place the corners there.If this answer doesnt help please tell me and also provide more info about the type of mop it is.
Dec 19, 2015 | Vacuums
How do i remove the power supply socket from the dyson wall mount
Hi Les, it's Jack at Dyson.
The end of the charger cord assembly which attaches to the machine itself is held in place securely by a friction-fit connection. You should be able to use something like a flat-bladed screwdriver to free the end of the charger cord from the docking station. Then with the docking station removed from the wall, you should be able to disconnect the charger cord completely from the rear of the dock, following the route shown in the image below:
I hope this helps - if you'd like any additional advice you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 04, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
Why is my eureka super broom not turning on?
When machine does not work, first check wall outlet ( plug in an hair dryer or table lamp to check wall outlet. ) and it that is OK than check your power cord for break ( if wire's are broken inside outer coating the cord will be very weak at that point )
May 15, 2014 | Eureka Super Broom 286 Vacuum
Seems to overheat and shut down
clean the hose very well that is sure to fix you problem I repair vacuums for a living this is very common do not use it again until you clean the hose really well stick a pole to a broom all the way through the hose and rinse the filters in hot water and let them air dry and it will run like normal when you push the broom stick through the hose it will free it of any debris if this does not work it is trash
Mar 19, 2014 | Vacuums
Hoover suction
I had a fur ball stuck in the pipe.  I took the end off and used a broom stick to clear it out.
Jan 13, 2010 | Miele Cat & Dog 326i Bagged Canister...
Makes a extremely loud alarm sounding noise while vacuuming and the cord in the back doesn't have good suction at all.
When you hear the whistling noise, means there is a clog either in the hose itself, or in the elbow where it goes in or from where the bottom tube bends and goes up. To clean hose, remove it, stick on top of broom/mop handle and push all the way down to clear out any debris on it.
Nov 20, 2009 | Bissell 6591 Power Trak Revolution Bagless...
There is no suction from the hose on a Kenmore Destiny Plus Vaccuum Cleaner
there is clog in the unit. Either the bottom or in the hose. If you can take hose off, stick hose on end of broom handle and push out clog.
Jul 09, 2009 | Kenmore Canister Vacuum Vacuum
Problems with Vac.
Check that the filter is not clogged. It needs removing and washing every 6 months.
Oct 06, 2007 | Hoover S2571 Quick Broom Bagless Stick...
Oreck Cord Free Electric Broom Quick Stick Vacuum Cleaner Logo
75 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
