Question about Sharp Notevision XG-P10XU Multimedia Projector
Trapeze image how to correct
What's considered Outdoor Play Equipment?
Outdoor Play Equipment may be considered all the recreational equipment present in playgrounds, such as seesaws, merry-go-rounds, swingsets, slides, jungle gyms, chin-up bars, sandboxes, spring riders, monkey bars, overhead ladders, trapeze rings, playhouses, mazes and all other kinds of equipment that can be used in parks, gardens and courtyards that help children develop physical coordination, strength, and flexibility, as well as providing recreation and enjoyment (Wikipedia)
Sep 17, 2013 | Toys
How do I recover the enable password on my Trapeze mobility exchange mx-8. Or how do I do a factory reset?
Hi Mate.
In case you still need to do this, or in case someone else stumbles on this problem and needs an answer, below is the the solution.
Connect to the MX device via console cable and recycle power.
Interrupt the boot process by pressing "q" followed by the "Enter" key when prompted.
at the boot> prompt enter the following command:
boot> boot OPT+=default (NOTE: This is case sensitive) and press "ENTER"
Presto, your devices boot with factory defaults.
Aug 28, 2012 | Juniper Trapeze Networks Mx-8 Wlc8r...
I don't know how to remove the seat to get to the batteries?
Under the seat there are 4 retaining clips connected to the trapeze bars (the bars going across in the front and back) Undo the clips and lift the seat off (make sure you don't grab by the armrests) Release the shroud fasteners at the back and take the shroud off. You will now have access to the batteries.
Feb 25, 2011 | Jet 3 Ultra Power Chair
How do i wire
how do I WIRE trapeze ctp-e54sx and make balance air circulation
May 19, 2010 | Zephyr Pyramid ZPY-E30 Kitchen Hood
How high is a PGL trapeze
varying heights depending on which centre you visit and even which trapeze base you were at - at PGL Beam House we have only 1 it is 23ft off the ground.
Apr 16, 2010 | Gregory Rock & Ice Climbing
Upside down images on my telescope. Bought used -no manuel. What to do?
In a refractor images are upside down as with most telescopes. You need an image erector to create a normal correct R and L and Up and Down image. It is a lens which goes in front of the eyepiece to give a correct image.
Jun 01, 2009 | Fieldvision 114mm Reflector (114 x 114mm)...
Bolt broke that holds saftey seat latch on - where to get parts?
one of the best places my be a Automovtive supply stores , you may also try a Home improvement store, they tend to carry "odd" Bolts, to remove the broken bolt you may have to drill it out with a special drill tip also avaliable at most of the Home Improvent stores,, make sure you take your broken piece with you if you still have it so you can get a perfect match.
Jan 31, 2009 | Jet 3 Ultra Power Chair
My lens fell apart
you should be able to thread the part that fell off right back on. Then just screw it till it stops. It sounds like is missing a screw that keeps it from coming apart. Its not a huge deal.
I have older lenses and take them apart all the time to clean.
now that's assuming it came apart in the middle.
but if your saying it ell off the mount then we have a whole nother problem.
if it just unlatched then just push the button on the side of the opening where the lens attaches and twist the lens counter clock wise after it sits evenly around the hole.
if you are not new to slrs please don't offended Im just going off the fact you said it came off
let me know if im missunderstanding,
Caleb
Jun 21, 2008 | Nikon Cameras
Code cof37
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print cycle, ATVC, or image stabilization sequence.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Dec 19, 2007 | Minolta CF2001 Copier
Sharp Notevision XG-P10XU Multimedia Projector Logo
14 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
