Question about Dorman 2003-2007 741-5102 International 9400 Series Power Window Re
2003 9400i international truck wont blow heat
Heat yesterday none today. fluid full in/out lines warm to touch. no cables, all electric
1976 chevy k10 350cdi base model no ac.will not warm up upper radiator hose gets hot heater lines both get hot but lower hose stays cold. changed thermostat filled till full ran air out of system no...
Check to see if the lever activated by the temperature control cable is actually moving when you move the control. Maybe a stuck valve in the heating system.
Dec 05, 2014 | Cars & Trucks
Our wii is about 6 years old. It was working fine yesterday, today it doesnt even act likes it's getting power. No lights come on. Reset doesn't work, switched outlets...nothing happening.
Wii console's are known to over-heat. Try letting it cool down for a day with no power cables plugged in. Try and turn it on the next day, and if it doesn't work, my best guess is that it over-heated to the point of giving up. And when you plug it back in, blow in all the ports and cables just to be safe. If none of this works, it is either broken or needs more expertise than I can give.
Aug 17, 2014 | Nintendo Wii Console
Front heat wont blow warm
Clogged coolant line or defective heater coolant line solenoid valve?
Nov 04, 2012 | 2006 Ford Expedition Eddie Bauer
I just replaced my thermostat and all fluids are full and my heat is blowing luke warm, the hose to the heater core is hot real hot still not blowing hot
Check the return line on the heater core. If its not warm or hot, the core has a clog. Will have to be replaced.
Dec 26, 2010 | 1999 Ford Taurus
2007 corolla does not give off heat, blows cold. temp shows correct range, heater core hoses hot to the touch inside and out, radiator hoses hot and fluid is sufficient.Would thermostat be at fault even if...
there should be a temperature door, but I don't know if there is a cable or if its electric. turn the temp knob, if it feels like it moves anything? I dont have a diagram here at home, but will monday/
Dec 06, 2010 | 2007 Toyota Corolla
Yesterday my air conditioner was blowing cold air today its blowing warm air what happened
if the compressor is turnning it could be you have developed a leak,or it could be that the air door which separates the heat from the ac is stuck open.vacume problem.if the compressor is not turnning it could be your low on freon,or an electrical issue.like a fuse or relay.
Sep 02, 2010 | 2000 Jeep Grand Cherokee
The car wont go into gear until its warmed up
it will not move because it is low on transmission fluid, warming the car casues the fluid to expand therefore making movement possible. also fluid looses viscosity when heated so you may want to look a full fransmission fluid and filter change. But still, get your car warm and check the transmission fluid, i bet its low. Dont forget to rate.
Jun 26, 2009 | 1996 Pontiac Grand Am
My 99 dodge dakota wont heat new thermostat motor
You have a bad heater valve, operated by vaccuum or cable its on the hot water line on its way to the heater core.
Feb 20, 2009 | 1997 Dodge Dakota
My 1979 chevy bonanza 4wd. pickup has started blowing transmisssion fluid out the dip stick tube,after the truck warms up a few minutes.thank you albert blair
turbo 350? if so it can be that it is over full or sometimes the gears that are in the tranny that sling the tranny fluid up will get bent or worn and will sling oil to the wrong spots and that will cause your gears to get hot and expand and that can cause it to shoot oil up your dip stick
Dec 04, 2008 | Chevrolet 1500 Cars & Trucks
Dorman 2003-2007 741-5102 International 9400 Series Power Window Re Logo
67 people viewed this question
Top Dorman Sport & Outdoor - Others Experts
Are you a Dorman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
