Question about Nokia Retail Supplies
Nokia 920 screen size
Reduce size print
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
Enlarge print
Which tablet, which application(s)?
Many tablets will reduce the screen size by making a "pinching" motion with your thumb and index finger in contact with the screen - and expand screen size by doing the opposite motion on the screen.
May 11, 2015 | Tablets & eReaders
Digitizer Problem
The digitizer could be bad or it's the wrong model type.
Dec 02, 2014 | Nokia Lumia 920
Digitizer problem
I don't know if there are two different models of a 920 or not. But you clearly have the wrong digitizer.
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
Need 2 unlock nkia lumia 920
Hi.
I see the website which offer to unlock Lumia 920 , I tried this website, they really unlocked my Nokia Lumia 920 from at&t, i would like Thanks & appreciate to Team of AT&T Unlock Code shop.They provide really good service , I hope this service provider will unlock your Nokia Lumia 920.
Once again thanks http://www.attphoneunlockingshop.us/
the link of http://www.attphoneunlockingshop.us/products/USA-AT%26T-Nokia-Lumia-920-IMEI-Unlock-Code.html.Thanks USA AT Nokia Lumia 920 Unlock Code Unlock Nokia Lumia 920 from AT USA USA AT Nokia Lumia 920 Unlock Code Unlock Nokia Lumia 920 from AT USA
Nice vid. This site explains all this in very easy to order format:
Aug 12, 2014 | Cell Phones
How to make big screen on nokia phone go back to small screen
Nokia phone? Please post model no. Usually there are two options there is the pinch to zoom , so place two fingers diagonally opposite each other and bring to the middle but this does not alter the big screen program in nokia phones , depending on the model you can hold the main menu button and close Big screen app , should return to normal size , more detail appreciated
Jul 07, 2014 | Apple iPhone Smartphone
My nokia 2700 classic the clock on standby screen is too big please tell me how i small the size of clock please
Open the MENU> OPEN SETTINGS>OPEN DISPLAY > and select the SCREEN SAVER-- you must scroll down to get this menu.
Now select another screen saver if you want to so that the clock is not displayed but the size cannot be reduced as it is default settings.
Aug 18, 2011 | Nokia Classic 2700 Cell Phone
When printing a duplex booklet, the printout is reduced in size with larger margins than in original document. How can I get it to print regular size?
It happens when the documents is on A4 size and the printer is set to print on letter size (which is smaller in size). Hence the printer automatically resizes the prints which result in larger margins and print as compared to the actual document.
Therefore, when you print the documents (Press Ctrl+P) you have to select the paper (A4) from the print properties.
Hope it helps! Good Luck!
CreativeTECH
Mar 02, 2011 | Brother MFC-9840CDW Laser Printer
Can't find "enlarge/reduce copy"
Scaled printing To enlarge or reduce a printed document by specifying a percentage, select 'Scaled Printing'. You cannot use this setting with borderless printing.
  1. Access the printing preferences by opening the printer Properties/ Preferences.
    For Windows Vista
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
    For Windows XP Home Edition
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  2. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'.
  3. In'Page Size', select the paper size specified in the application. If youselect a size that cannot be selected in your printer, a message willdisplay informing you that the setting has been changed to'Fit-to-page' printing. Select 'Scaled Printing' again.
  4. In 'Orientation', select the same orientation as specified in the application (either Portrait or Landscape).
  5. In'Printer Paper Size', select the paper size loaded in the printer. In'Scaling', the magnification at which the document will print so as tofit exactly on the output paper size will appear as a reference value.
  6. In 'Scaling', specify the percentage. You can select from 20% to 400%.
  7. Click 'OK'.
I hope this information allows you to resolve this issue.
Please be aware that you can freely access Canon's online support solutions site by clicking here
If I've managed to answer your question, please take just a moment to rate this post. Thanks!
Apr 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Retail Supplies Logo
73 people viewed this question
Top Nokia Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Nokia Retail Supply Expert? Answer questions, earn points and help others
