Question about Fender Music
Fender mustang noise
On my new Mustang IV there is significant noise on many presets, and the noise varies from preset to preset. I can reduce it a bit with the noise gate, but not totally, and that limits your dynamics. I have the noise even if I remove the input cable, seems related to the software.
    Sergeant:
  • 336 Answers
This isn't much information to go on. I may can help if you could be more specific. What amp? Presets of what? What software? What noise gate? Where is this noise, amp output or pc input? A computer sound card can do weird things when musical equipment is plugged into it, some mice will do it, making noise when you move the mouse around. I'm guessing how you are set up, if you get back to me, I will try to help you further.
Posted on Mar 29, 2014
  • 3741 Answers
SOURCE: I bought an Alesis SR-16 drum machine from an
click this link directly
Download the complete
user guide (490 Ko)
---- the link is of the user and trouble shooting manual.in that all the possibilities which can be done are mentioned.you can try all the possibilities one by one.
and yes you can transfer data from one sr-16 to another sr-16 .first you will have to tranfer the data from sr-16 to your pc.then connect the another sr-16 and transfer the data to the erased sr-16.
click the link and check out the possibilities.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 20, 2009
  • 5603 Answers
SOURCE: I have a Fender Cyber
Check for degradation of C144 a 2200mfd/16volt cap.
This is power source for the 5 volt digital hardware. Check for excess ripple with a scope. The voltage should NOT go below 8 volts. If the voltage dips, the DSP will go nut-case.
Posted on Sep 30, 2010
  • 5603 Answers
SOURCE: I have a Fender Deluxe Active Jazz Bass thats
This sounds like either a bad guitar cable or a bad jack in the guitar. Possibly your friend is not as qualified to find these intermittent problems as needed? These jacks are really junky and often have riveting of the barrel come undone... especially if the retaining nut is overtightened. The LONG barrel like jacks are notorious for failing. You have all the information you need to solve this problem. First try a different guitar cable... (often they are broken or intermittent at the end where they flex). If that doesn't fix it, replace the jack in the guitar. Also verify that the conductive coating paint within the guitar is grounded. Sometimes the contact to it is destroyed when the volume control shafts or jacks become loose and they depend upon the shaft barrel to ground the paint.
Posted on Jan 31, 2011
  • 5603 Answers
SOURCE: ON my fender mustang II
Possibly you are holding the switch down???... it MAY activate on the release of the switch. Try quick tap on switch.
I tried to find schematic to analyze this but could not find one.
Posted on Apr 06, 2011
rokrgyrl
  • 6 Answers
SOURCE: How can I fix the buzzing noise on my Fender Frontman 212R if I've identified the cables and guitar itself as not being the problem?
... do you, by any chance, have non humbucking pick ups on your guitar? Just curious...
Posted on Sep 14, 2012
Serial number 310574 fender mustang bass
That should be 1972-73. Value will depend on condition and your location's market, but I would say arounf $1000 in very good condition with the case in my area.
Oct 26, 2015 | Fender Music
How do i transfer music from my computer to my mustang l(v.2) guitar amplifyer
You plug into your headphone jack on the computer with a cable that has one jack on each side then plug the other jack into a 1/4 jack adapter & 3.5 mm then plug your guitar cable into the adapter and the other side into your amp
Sep 28, 2014 | Fender Mustang Guitar Amplifier 20 Watts...
Fender serial number lookup
it is a 1978 mustang bass S=seventy 8= the year but condition and originality mean everything
Aug 06, 2014 | Fender Musical Instruments Corporation...
Static
are they hi gained presets (distortion)? if so, that woulld be typical of mast amps, However, polarity of the ground can amplify that white noise. most amps have a polarity switchfor ground on the back. if not you may be plugging into an older socket which doesnt have good ground. it can be resolved at the service panel. thats a whole different procedure. let me know
Mar 30, 2014 | Fender Music
ON my fender mustang II as I switch channels with my footswitch there' s a lag before the sound comes up
Apr 06, 2011 | Fender Mustang II Guitar Combo Amplifier...
I have a Fender Cyber Twin (1st edition, dont have serial number to hand) which I purchased 2nd hand from Ebay. Lately it has had a fault which started off as quite intermittent but has got worse. When...
Sep 30, 2010 | Music
I have a Fender Cyber Twin that does not save my settings. I can set up my volume,gain, treble ect.. hit save button to store the setting and if I switch settings to a different sound and back to the...
From the manual... is THIS the proceedure you are using to save the settings?
 T o SAVE:
1) Press the SAVE key once and a prompt displays the PLAYER’S
LOUNGE preset about to be replaced, (example prompt shown).
2) Rotate the DATA WHEEL to select a PLAYER’S LOUNGE preset to
overwrite with the currently active amp design
(last chance to press EXIT, cancelling the save).
3) Press the SAVE key a second time to complete the save.
Jan 24, 2010 | Music
Cyber Twin selector knob.
The selector knob may be a potentiometer or a rotary impulse giver device. In any case, it looks like the internal contacts are either dirty or oxydized so the value is changing in an erratic way which causes the unit to skip several presets at a time.
It would require a skilled technician to disassemble and clean the controller (if it can be disassembled in the first place), otherwise you will probably need to replace the preset selector knob entirely.
Regards,
Triarcuate
Oct 07, 2009 | Music
New speakers required?
Possibly, however if output from ME50 is to "hot", that might be some of the culprit (overdriving input)
Sep 14, 2009 | Gibson Robot Flying V LTD RM
Music Logo
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
