Question about Vehicle Parts & Accessories
Toyota tazz rear brakes
Show me all the sprjngs on the rear brakes
  • 139 Answers
SOURCE: Minimum disc thickness on Tazz
It is stamped on the inside of the disc. You have to remove the disc.
Regards
Phillip
Posted on Sep 18, 2009
  • 324 Answers
SOURCE: 1998 Toyota Tazz Door Panel Removal
probably has a bunch of plastic push pins holding it on, you should pull those carefully as the panel is probably easliy breakable, but those pins maybe hard to get out so use tools and slow caution
Posted on Jun 19, 2010
  • 200 Answers
SOURCE: 2003 Toyota Tazz 130
you will have to replace brake line and if you cant get old line out wheel cylinder
Posted on Sep 03, 2012
  • 5341 Answers
SOURCE: how to remove rear brake drum on a toyota tazz 2004 model
3 methods: Sometimes you have to get to the adjusters from behind the drum, and turn the brake shoes inward, so the drum slides past them. Sometimes tricky to turn the adjuster wheel inside the drum (look for a rubber plug to remove and see the adjuster.) A couple of small screwdrivers will be needed, one to turn the adjuster wheel, and one to push a little clip away from the adjuster wheel so it can turn-tricky till you get the hang of it.
2. Best way to remove the drum, if your drum has two small drilled and threaded holes just out from the drum's center hole and opposite each othe on the drum-those holes are for drum removal. Find or buy two short bolts that will fit the holes and turn them in evenly. The bolts will contact the backing plate and force the drum outward. Usually you need to get it just moving a very little, then it will come off.
3. As a last resort, you can always heat the drum with a propane torch till the metal expands from the heat (15 minutes?). Tap it all around with a hammer, it should come free. Often what holds the drum fast is the center hole can have a rust build-up-sort of tacks itself to the center hub.
Posted on Nov 17, 2012
SOURCE: Toyota 2002 Tazz Manual
my tazz gooi een van die vonkproppe nat met olie. wat ek ek doen om die probleem op te los?
Posted on Jan 22, 2013
I am driving toyota Tazz 2005 model- brake lights are not working, the fuse blown everytime I change the lights, the even damaged my car radio. Pleas e help
if your fuse is blowing then you have an overload of current in the wiring between the brake pedal and the the brake light, check to see if you have a short to ground
Mar 18, 2015 | Toyota Cars & Trucks
Cars and trucks
Sometimes braking a timing belt causes many internal problems. You may have other issues besides the belt.
Apr 06, 2014 | 2005 Toyota Tazz 130
Too heavy on fuel
there is no carb. in modern cars, unless...
what country are you in, cabs ended in 2006 in far from USA countries.
so that you? in S.Africa or some small Island in the Pacific running JDM cars?
quote, this you?
A facelifted version of the sixth-generation five-door hatchback was made in South Africa as an entry-level model called the Toyota Tazz from 1996 until July 5, 2006. The Tazz was offered as 130, and 160i. It was also sold as a panel van called the Carri. [4]
end quote.
why not post photo of engine.
or get the FSM on this car, factory service manual, at Toyota.
it covers all THAT.
if not a carb, you cant tune it, like a carb , you fix it.
my first idea> give it a tuneup, new spark plugs, filters.
Jan 23, 2014 | 2005 Toyota Tazz 130
Toyota Tazz 2003 model
My left steering arm of my 2003 Toyota tazz 1300 is loose inside the steering rack how do i fix it. Please can u help
Jan 07, 2014 | Toyota Tazz Cars & Trucks
Sep 03, 2012 | Cars & Trucks
Rear brake pipe broke off inside the rear drum how do i get the broken piece out and hoe do i repair it again to working condition
remove the wheel of the drum then remove the drum if its stuck you gonna have to use a hammer a bit after you removed the drum remove that broken piece i recommend that you buy a new one to replace the broken then ur done
Sep 03, 2012 | 2005 Toyota Tazz 130
Toyota tazz 1300 carb adjustment
can a toyota tazz 2006 automatically adjust tappets
Feb 16, 2012 | 2005 Toyota Tazz 130
Jun 19, 2010 | 1998 Toyota Corolla
Regards
Phillip
Sep 03, 2009 | 2000 Toyota Corolla
http://www.motorbooks.co.za/details.php?prod_id=4879
Aug 28, 2009 | 2002 Toyota Corolla
Vehicle Parts & Accessories Logo
15 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
