Question about Akai LCT3201TD 32 in. LCD Television
Lct3201td it shuts down after 30 min. of being on
Check the sleep timer settings
Posted on Jan 02, 2008
After working o.k. for 30 mins my sony pcg-3e2l computer shuts completely down.
1. Check the battery is charging.
2. check it works continuously when using the mains adaptor.
3. Check the power settings to make sue it does not hibernate or shut down after 30 minutes of non-use.
Sep 30, 2014 | Computers & Internet
Why my treadmills shuts off after 30 min
1) LUbe the deck belt, the lack of lube produce Shut down, by enough friction between deck vs deck belt
2) Lube the rollers bearing very well
3) Measure the input voltage motor, if there are the motor need repair
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
5) Run the software calibration, for diagnose, and troubleshooting.
God bless you
Jun 09, 2012 | Exercise & Fitness
Generac gp6500 will not stay running for more than 20 minutes.It shuts itself down then it is hard to restart and when it does start it will not continue to run. If I let it sit for 20 min. or more it will...
Here is support product lookup. Requires more specific numbers about your gp6500.
Shuts down automatically from oil shortage.
Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Jun 07, 2017 | Generac 5623 GP Series GP6500 8,000 Watt...
Runs 30-45 mins then shuts off
Sounds like you need to replace the ignition coil,it may have leaked out it's coolant and the it will go to ground when it is hot.
May 15, 2010 | Garden
Must wait 30-40 mins to restart engine
Check your manual to see if it call for premium or regular. Premium has less energy per gallon and is designed for higher compression engines. What makes it "premium" is more anti-knock compounds - not better quality or performance. Sounds like a vapor lock problem that resolves as the engine cools. Regular gas may help with that.
May 03, 2010 | Briggs & Stratton 3000 PSI Pressure Washer
Gas dryer runs for 30 mins then shuts off.
This is a common problem that is not a good one. But the motor is goin bad. If you try to start it you will hear like a hum then start. Motor is going bad and over heating and shutting down on overload. Sorry. Hope this helps.
Jan 31, 2010 | Kenmore Dryers
Ryobi SS30 starts great, runs fine, quits
the engine is getting to hot & shutting down either not the right fuel mix or not enough oil in engine sometimes the mixture screws need to be adjusted
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Hitachi 60EX38B shuts down after 30 min or 45 min of viewing.
I would offer that you at least take the back off and give it a good cleaning - compressed air etc .. its gotta be dusty .. the dust could be causing some heat problems
Mar 08, 2009 | Hitachi 60EX38B TV
Akai LCT3201TD 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
