Question about EHEIM NORTH AMERICA Eheim Classic Aquarium Filter 2260
2260 filter stops pumping
Water in pipes motor makes a rumbling noise
Noisy & will not progress to spin cycle
The tub must pump down before it will go into spin cycle. My pump was making rumbling noises and when I took the basket out (simple process) there were a couple of bobby pins stuck in it. (kids) Cleaned it out and checked the flowpath with a wet and dry vacuum on the drain connection. Still makes the noise. There is a small zip lock bag under the control panel that describes the trouble shooting and error codes. It also says how to go through the diagnostics steps. Hope this helps.
May 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
Rumble/clacking while draining & spinning
Check for debris in filter of pump assembly. The filter unscrews out of the machine. It is located behind the bottom panel. Remove the two or three screws holding the panel in place, gently ply down and you will see what looks like a handle. It will be hard to turn but unscrew it and check to see if there is any debris. Have towels near by as there will be quit a bit of water coming out as you remove it. It the unit still makes noise there is a good chance the pump motor is going.
Feb 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machine repair
you guessed it, check the pump for blockages etc, replace if no blockages, this should cure your problem but the info you have given is vague
Oct 02, 2007 | Washing Machines
Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
Jun 14, 2007 | Bosch Axxis WFL 2060 Front Load Washer
EHEIM NORTH AMERICA Eheim Classic Aquarium Filter 2260 Logo
67 people viewed this question
Top EHEIM NORTH AMERICA Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you an EHEIM NORTH AMERICA Fish Expert? Answer questions, earn points and help others
