Question about Carson Sirens sc-1002 volunteer full featured siren
Wont put out sound
Q 1 in side will start to smoke when power is on
    Genius:
  • Carson Sirens Master
  • 1,795 Answers
You have a short in the circuit of Q1 that is making it smoke.As long as it smokes it is doing its job. get a voltmeter and trace backwards from Q1 to the component in question. Replace it and you should be fine to go.
Posted on Jul 05, 2014
Echo srm 225 manual
Smoke generally means you have too much oil to fuel ratio in your mix. Mix per manufacturer 50/1 exactly and try again.
Sep 02, 2014 | Garden
1.6 liter vw diesel engine will not start
You have a blown head gasket.
Mar 03, 2017 | Cars & Trucks
My truck is blowing white smoke out the tail pipe and I have no power wont go but I can idle around its a 2055 f250 turbo diesel, 300000 kms...litterally just started doing this a couple days ago..now ...
White smoke for a diesel means air in the fuel system. You will have to start at the engine, I start at the line going to the fuel pump. Get some fuel in a can, remove the line to the supply side of the pump and put another line from the can to the pump. If it starts and doesn't smoke , then you have to work your way back to the tank and find the spot that is sucking air. If it doesn't start the I would replace the filter first, check again. There is a possibility that the injector pump is bad, but these don't usually throw white smoke. They just make the engine have very little power or no start.
Sep 21, 2011 | 2004 Ford F250
Bike lacks bottom end power and topend doesn't hit band properly and it bellows smoke but its like gear box oil smoke its not running rich it has a new set of piston and rings the carby is fine and at...
Who put the new crankcase seals in your bike? Sounds like your sucking oil out of your crankcase if it is blowing all that smoke.just fixed Cr125 doing same thing.
Dec 20, 2010 | 2003 kawasaki KX 125
Need to rebuild carburator on skilsaw chainsaw 1631 type 3,Cleaned the fuel line and filter,starts for few seconds if put gas in carburator but wont **** gas from tank
On a different thread:
Oct 22, 2009 – your comment
Got it started by cleaning carburetor but it smokes quite a bit played with 2 screws on side going in all the way and backing out one and half turn still smokes
Oct 22, 2009 – my reply
Tune it until it idles and cuts properly. 1.5 CCW is a good starting point. Tune for performance. 1 turn CCW is as lean as I’d go. Clean air filter, fresh mix, fully warmed up, bar mounted and properly tensioned. HTH
Lou
Oct 20, 2009 | Garden
Dodge caravan starting problems
hate to tell you this... it does sound like a blown head gasket
Robert
Jan 27, 2009 | 1996 Dodge Caravan
2.0 litre 2002 wont start
hi from uk just a couple of questions ? as car is now with this cold starting?? when engine does start do you get blue/black heavy smoke and engine has a slight hesitant ? then smoke clears ? engine runs ok? and no problems starting for rest of day ? if this sounds like the problem you have? then this is the glow plugs that arenot working at optimum you only need 1 or 2 poor and engine has trouble cold starting may i suggest you first check that when you put ign on there is power reaching the 1st glow plug at least? if ok this will eliminate relay and fused link? these glow plugs must glow white hot from tip upwards you can change these diy with a little patience and are obtainable fro most motor super shops here in uk anyway hope this helps?and inspires you? please update on how you go on? or if you req further info ?
Nov 21, 2008 | 2003 Hyundai Santa Fe
Carson Sirens sc-1002 volunteer full featured siren Logo
Top Carson Sirens Radio Communications Experts
eradiostore
eradiostore
Are you a Carson Sirens Radio Communication Expert? Answer questions, earn points and help others
