Question about Creative Labs MegaWorks THX 250D Computer Speakers
Buzzing sound issue
Sound noise issue
My DigiTech RP355 turns on but only buzzes
Sounds like a classic ground-loop issue. Sound-on-Sound had a great article some time back that may help you.
Apr 10, 2014 | Music
Tv making a buzzing noise
I would check the Flyback, and horizontal output transistor. Could also be a grounding issue. If you're not familiar with fixing them get it serviced.
Dec 28, 2012 | Philips Magnavox 27MS343S 27" TV
A loud buzzing is coming from the back of my sanyo ds 25390 tv. picture and regular sound is fine
If it is a high pitched whine or buzz it is likely a transformer vibrating so hard it is making the noise.
There are ways to try to deal with this issue but the set has to be opened and probed to locate where it is coming from--
for example with back off and set on a plastic rod can be used to touch areas and exert slight pressure until the sound changes or goes away--then either replace the part or I have used hot glue etc to stop it.
You first have to locate the source of the issue:
find where it is coming from.
Mar 24, 2012 | Televison & Video
Speakers had a buzzing/vibrating noise. had them replaced. still making same noise. happens on very low and loud volume. any idea what it could be? possibly the sound board?
maybe just poor speakers.....had a similar problem with an old sony. Replaced the speakers twice and always had a noticeable buzzing. Try running external speakers (computer speakers will work) at low volume to see if you hear it in those. If so, you may have sound board issue.
Jan 03, 2011 | LG 37LG30 37 in. LCD HDTV
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
The TV just started making a loud buzzing noise last week, the buzzing sounds begins after the TV has been turned on for 15 or so minutes- the sound stops about 15 seconds after the TV is turned off. The...
This tv have a colors wheel. The tv colors wheel is dead.The buzzing noise is the cause of the colors wheel is spinning of is axis and rubbing sides of the motor.Hire a tv tech. for the job.Colors wheel is hard to replaced,because have to take out many other machanical parts,even before can change the colors wheel it self.
Aug 31, 2010 | Samsung HL-P6163W 61" TV
Hp p2015 laserjet makes constant buzz sound
this sounds like a possible fan issue, check the vents to pinpoint the noise and then replace the fan that you hear the noise coming from... if you need to order the fan, just let me know and I'll find it for you . hope this helps, if so please mark Fixa!!
Jul 18, 2010 | HP LaserJet P2015dn Printer
Loud buzzing while other phone is on base. Switching phones on base has no effect on issue. Taking phone off base hitting 'talk' helps with issue, but buzzing returns upon placement on base..
did you have "buzzing" Before these phones? Anything electrical fan etc on the same circut breaker of your house?. Or buzzing start recently with these already running. It sounds like your describing "electrical noise" and not really a issue with the phoned them selves. Try relocating the base if you have another open wall jack and on another circut. If you notice it goes away check whats all on that circut (wall outlet) that you unplugged the base from. depending on the noise or lack of at the new location it would probly be something running on there. ..
Hope this gives ya a solid start on a fix :)
Nov 13, 2009 | Uniden 5.8GHz Cordless Phone
Make loud buzzing noise when powers on
Actually that buzzing sound seems that it might be an issue with your ballats, it may start to go out sometime soon.
Jul 26, 2009 | Toshiba 52HM95 52" HDTV Projection...
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Creative Labs MegaWorks THX 250D Computer Speakers Logo
32 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
