Question about Brother MFC 8820D All-In-One Laser Printer
LP2403001 HINGE ASSY L
NEED THIS PART
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
I believe we have this part in stock. You can email info@villagecomputerservice.com for a price and availablility...
Posted on Mar 27, 2014
Hing broke on copier can i get parts for that
Spare parts are available here (Brother MFC8440 Doc Feeder Parts).
Left hinge is one part, right hinge requires one or two separate parts
LP2403001 HINGE ASSY Left
LE6244001 HINGE BASE Right
LE6245001 HINGE ARM Right
Dec 29, 2010 | Brother MFC-8440 All-In-One Laser Printer
Can't close doc cover properly - seems 'broken' at hinge - can I fix this myself?
The left hinge breaks often enough that Brother changed the part number of the part. I hope that means the new part is stronger; I haven't seen one come back for a second repair. Assuming it's the larger, left hinge that's broken (It always is.), you need an LP2403001 HINGE ASSY L. You can find it from a servicing dealer or online, and it's easy to replace.
Look at the back of the machine and find two large phillips screws in holes. They keep the hinge blocks from coming up all the way out of the machine. Remove both of them and lift the top cover up until it's connected only by its cable. It might take a helper to hold the cover, but you need to unscrew the hinge assy. from the top. The three screws are obvious and easy to reach now that the cover is loose. Put the new hinge on, lower the top back down so the hinges drop into their holes, and put those screws back into the holes in back. You're done.
Jul 11, 2010 | Brother MFC 8820D All-In-One Laser Printer
Canon fax machine says "cover open" and won't do anything till the msg is cleared. How do I clear this msg when my cover is in fact closed?
You may need a new hinge, the one in the left rear breaks and gives that error when the scanner cover doesn't go all the way down. the hinge is part #
LP2403001.
Dec 04, 2009 | Brother MFC-8440 All-In-One Laser Printer
Need left hinge/spring box
Precisionroller.com
their part number is H7914
Brother part number is LP2403001
Nov 18, 2009 | Brother DCP-8040 Copier
Paper jam on top tray, can't find any jam
On that machine the hinge in the left corner for the scan assembly breaks and keeps the lid from shutting properly. The hinge is # LP2403001. Otherwise shine a light up the paper path from below and see if there's a paper scrap inside.
Nov 13, 2009 | Brother MFC-8460N All-In-One Printer
Hinge and paperfeed
You need a new hinge, #LP2403001, and the grinding is because the fuser has a broken gear.
Jul 25, 2009 | Brother MFC-8840D All-In-One Laser Printer
The cover or lid hinge, left side, spring loaded has broken. looking for a replacement.
The hinge you need is #LP2403001. You might be able to order direct from Brother, but there are many sources on line. around $15.00
Jun 23, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 8420-- hinge?
i went to Brother site and opened support.
searched for parts and got a listing of technical support shops in my area. called the first one listed and asked if they had the LP2403001 hinge in stock and they came back with an affirmative answer. will pick it up this afternoon locally.
You can see an image of the hinge assembly at ebay if you search for LP2403001.
Regards,
David
Jan 25, 2008 | Brother DCP-8020 Laser Printer
Brother MFC 8820D All-In-One Laser Printer Logo
89 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
