Question about Zojirushi Kitchen Appliances - Others
Kneading It made a noise and then stopped kneading
Oster noise when kneading
Are you pushing your pan down into the oven so that the little spring clips hold your pan in place nice and snug?
Jan 25, 2014 | Kitchen Appliances - Others
The kneading mechanism just stopped kneading :( so sad! It's pretty old I guess. Do I have to bury it or is there a quick fix?
Be sure your machine is unplugged and take the panel off the bottom of the machine. Take a look in there and you will probably find that your drive belt has snapped or come off. If so contact breadmachineshelp.com for a replacement belt.
Jan 05, 2012 | Kitchen Appliances - Others
I have a toastmaster Bread Box bread machine...I am making French bread...the banging noise was so loud I stopped it fearing the machine was broken...is it ? If not should I continue the kneading/baking...
Unless the sound is mechanical like metal on metal etc. what you may be hearing is the sound of the dough ball being knocked around and kneaded. Sometimes that gets pretty loud. While it is kneading go ahead and open the top and see if you think the dough ball is making the noise. If it seems to be coming from somwhere else then you may have a more serious problem. Is this a new noise or it this the first time you have used the machine?
Nov 08, 2010 | Toastmaster 1183N Bread Maker
My machine seems to labor in the kneading cycle, then stops and you hear that engine noise of it trying to knead the dough. I follow the recipe exactly. the machine worked well for about 3 months, the...
Hi, Take the pan out of tha machine and see if the paddle spins freely by hand. If yes that's great...if no then the sealed bearing might be sticking and starting to fail. Next check the tension on the belts. The motor and belts are located in the base of the machine. Be sure to unplug machine and ask someone to help you if you are not mechanically inclined. Hank
Sep 23, 2010 | Black & Decker B2250 Bread Machine
Basket is not staying in place during the kneading process and the noise is unbelievable! Help!
Take the bread pan out of the machine. Start a kneading cycle and see if the noise is still there. If yes then motor spindle is bent, the motor is bad or the belts are pulleys need attention. If the noise you heard is not as bad, then it is the seal on the bread pan ( the seal and shaft that the paddle goes on).
Hank
Nov 18, 2009 | Cuisinart Kitchen Appliances - Others
It stops kneading and won't start again on its own. The only way to get it going again is to put it on "pause/stop", then push "start".
We have 2 machines.... BOTH operate about the same.
Load the raw materials and press Start. The both Knead for awhile the stop for a period of time to allow the dough to rise.... then start again... then pause for some time.... The knead and rise times vary with the setting we put in for our receipt/bread type.
Does this help/provide and insight?
-Jim
Oct 17, 2009 | Kitchen Appliances - Others
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Kneading Blade chattering
I had the same problems with another manufactures model. I found that the bread pan needs to slot in the machine only one way. The pan will fit in the machine with the handle both vertical and parallel to the front. However to stop the clacking noise I found that one way in the machine..it makes noise, the other way it doesn't. You'll have to try. If it makes noise, open the lid and turn the bread pan 45 degrees in either direction and secure it back in the breadmaker then close the lid. I hope this helps. If it does, remember how the pan is in the machine for next time to avoid the noise.
Jan 02, 2009 | Sunbeam 5891 Bread Maker
Loud noise and not kneading
No, not normal. Your belt is probably gone.
Feb 20, 2008 | Sunbeam 5890 ExpressBake Bread Maker
Kitchen Appliances - Others Logo
29 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
