Question about Karcher WV50 Window Vacuum
Window vac about 1 year old not working does not **** up water
Window vacuum about 1 year old does not now **** up water . worked fine until about 2 weeks ago
Belt falls off Dirt Devil upright
I have a Hoover canister vacuum it works great.
I think you have the right idea. Good Luck!
May 15, 2017 | Vacuums
My Shark steam cleaner just stopped working - doesn't make steam anymore. Is there a way to fix it.
I have the same problem - just heard from the support tech to soak the "device" in 1/2 vinegar and 1/2 water. Read on line a customer used vinegar in the device itself, heated it up until it made steam, then emptied it and used distilled water and it was fine. I haven't tried it yet, so we'll see if either solution works . . .
Mar 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Bissel proheat is not sucking up water
There is a oblong black seal that sits where the tank lip and the clear noozle window come together, is it there. Also make sure the filter in the tank lid is clean.
Jul 09, 2008 | Bissell 1699 ProHeat Clear View Upright...
My old Tristar canister vac.
If you have a voltage meter you could see where the problem lies. All TriStar parts including the motors, both the nozzle head motor and the actual vacuum motor are purchaseable online through www.totalvac.com
I have ordered parts through them and everything arrives no problem and they are priced nicely by the way.
Feb 11, 2008 | Vacuums
Aqua vac vacuum cleaner
yes you do need water... but water vacs dont clean as well as a good old suction driven machine.... aerus has several great models available
Feb 05, 2008 | Vacuums
Power nozzle not working on my vac but does on another vac
Is there a reset button somewhere on the power nozzle? Most of these have a breaker to prevent the motor from burning out.
Feb 08, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Karcher WV50 Window Vacuum Logo
65 people viewed this question
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
