Question about Canon LS-100TS Calculator
Lost decimal point
Rounding up and no decimal
How do I stop calculator from rounding up?
Hi Carol,
There are switches at the top just under the screen called the "Rounding Switch" and the "Decimal Point Selector Switch".
With the rounding switch you can select rounding up or down, but you may also want to use the second switch to show more digits after the decimal. Put it in the "F" position to show all decimal places. When it is in the 0, 1, 2 positions, it strips off and round the numbers.
Here is the link to the manual as well, look at the section detailing the "Decimal Point Selector Switch".
(You will need an Adobe Acrobat Reader to look at the manual.)
Hope this will help you. http://downloads.canon.com/cpr/software/calculator/P23-DHV-(USA-HWB).pdf
Nov 15, 2014 | Canon P23-DHV Calculator
HP 14B need to set decimal point
Shift (yellow) button and DISP (above close parenthesis).
N button.
Will show FIX _
Input required number of decimal places
That's it!
Feb 13, 2014 | Office Equipment & Supplies
My calculator is rounding to nearest whole number. How do I fix this?
You should move the rounding switch on your calculator. It has three options: an up arrow on the left side (for rounding up) a 5/4 sign in the middle (for rounding off) and a down arrow on the right side (for rounding down). borbalint.png
You may also have to move the decimal point selector switch to set the decimal point position.
Mar 15, 2011 | Canon P23-DHV Calculator
How do i fix the rounding of decimal points to not be rounded on my ti BA II plus?
Press 2nd [FORMAT], type a digit representing the number of digits you want after the decimal point (or 9 for floating), then press ENTER 2nd [QUIT].
Nov 18, 2010 | Texas Instruments BA-II Plus Calculator
My TI-30Xa circa 1995 has suddenly started rounding up on the 1/10 digit. How do I correct this or is my calculator fried?
Press 2nd [FIX] then the number of digits you want to the right of the decimal point. [FIX] is on the decimal point key.
Nov 07, 2010 | Texas Instruments TI-30XA Calculator
I have a SHARP EL-738 financial calculator. How do I set the decimal rounding to more than 2 decimal.
Press SETUP 0 0 then select the desired number of digits to the right of the decimal point.
Aug 12, 2010 | Office Equipment & Supplies
Rounding up
By default the BA-II Plus displays two digits to the right of the decimal point, for dollars and cents. To change the number of digits, press 2nd [FORMAT] and a digit from 0-8. Use 9 for floating decimal display.
Jul 08, 2010 | Texas Instruments BA-II Plus Calculator
Rounding off in Casio FC 200V
Press [SETUP] select FIX then press [EXE]. Enter the number of decimal digits you want (3 or 4). Press [ESC] then press [EXE]
Hope it helps.
Dec 14, 2008 | Casio FC-200V Scientific Calculator
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Canon LS-100TS Calculator Logo
old marine
old marine
