Question about ReliaBilt Building Materials
The window, as soon as i unlock it, opens ITSELF! No joke! It is perfectly square, plumb and level. Is it GHOSTS?
  • 4 Answers
If it's a double or single hung window: On each side of the operable sash is some type of tensioner to keep the window from dropping. It sounds like the tension is set too high. I would need specifics about your window to explain any further.
If it's any other type of window: Call Ghosthunters.
Posted on May 02, 2014
Is this a vinyl, wood, aluminum or other type of window? And is it a slider, single hung, or double hung?
Posted on Apr 29, 2014
Fisher and paykel fridge is making a whining noise only when door is closed. Thanks in advance.
If this is a large cabinet or larder fridge the cabinet is not rigid enough to maintain it's shape unless it rigidly stands level and square. It can take a deal of time and effort to adjust the front feet in order to level and square the cabinet on a relatively flat floor and sometimes it is impossible without first preparing the floor.
It is important for them to stand level and square and at the same time stand firmly on all the feet. If they are allowed to operate out of plumb for any length of time the motor/compressor unit can soon become noisy. Often this is only noticed when the door is closed or open. The door is a major part of the rigidity of the modern fridge and if the fridge is not properly levelled the shape of the cabinet will change as the door is opened and closed causing any compressor noise to be transmitted differently.
The gas charge of the modern fridge can also make weird noises as it is being pumped around the circuit. Ours sometimes sounds like the wind blowing across an open chimney and sometimes like the sea breaking on to a pebble beach and sometimes like something sprung a leak. All this is fairly normal after the fridge has lost it's youthfulness.
Jul 23, 2016 | Fisher and Paykel Refrigerators
How can I repair my laser?
Simple answer, you cant. The PLS hand held lasers are not designed to be opened, or repaired. You will have to remove a decal to get the screws to open it, and doing so will mean the laser wont be sealed anymore. They are very susceptible to dust and debris. You can get it replaced with a PLS etn, from a PLS retailer. For free if you're under warranty, and for a reduced cost, if your not.
Aug 09, 2015 | Pacific Laser Systems PLS5 Automatic Laser...
My level wont turn on
I would suggest contacting one of our Factory Service centers so we can take a look at it. Please click the link provided. DEWALT com
Mar 16, 2015 | Dewalt Dw084k Self Leveling Level Plumb...
Door sticks terribly...
First check to make sure that the hinges are securely fastened to the door jamb. Gently try to tighten all screws but be careful not to over-tighten or strip the screw heads. It's possible loose screws could be causing the door to hang slightly making it fit improperly into the door jamb.
It's also possible that the door frame isn't 100% "true" and it could be causing the storm door to get caught along the top or bottom edge. You can check with a level to make sure that both sides of the door are plumb (perfect 90 degree angle). You can also use a carpenter's square to check that all of the interior angles in the door jamb are 90 degrees respective to each other.
If everything is square then it could be that the hinges on the storm door are not aligned properly. With the storm door slightly ajar use a level on the vertical edge both at the top and the bottom. It should, ideally, be the same as the door jamb. If it's slightly off you could try shimming either the top or bottom hinge as necessary to even the storm door until it is aligned with the door jamb.
If you find that your door jamb is not "true" then you may need to consult with a carpenter or storm door installation expert to find a way to trim your storm door or refit it for easy opening and closing. Many older homes settle over time and sometimes door jambs slip out of alignment. The door itself may still open and close as usual but it may have sufficient gaps on all sides to prevent it from getting stuck. The newer storm door may be too tight a fit and catching on a door jamb that has settled out of true.
Feb 27, 2015 | EMCO Door. Forever 36 in. White Composite...
Where can i get my pls5 laser repaired
Gendron's in Spokane Washington
gendrons.com
They did a perfect job on my laser transit
Jan 28, 2010 | Pacific Laser Systems PLS5 Automatic Laser...
Turn unit on and it flashes but it won't level
Firstly, check batteries are fresh and new. Secondly, the unit itself has to be within 5-10 degrees of level before it will level itself out. If it is outside this range, i.e. pointing too far up or down, the lasers will flash toi indicate this. So just check the unit itself is sitting somewhere close to level to begin with, because the levelling gyros only have a small range in which to operate.
Oct 05, 2009 | Robotoolz Laser Level With Simultaneous...
Expert staffs
Under Time Trial you can unlock a range of charcters and vehicles by either
setting times or unlocking Expert Staff Ghosts.
Normal Staff Ghosts are automatically unlocked and
ready to race against in Time Trial mode for a good thrashing, and beating
these by several seconds unlocks an Expert Staff Ghost.
Hope this will Fix Ya!
Jul 13, 2008 | Nintendo Mario Kart (Wii) for Wii
Oven door stays slightly open
The unit may be out of plumb ( square to the floor ). I suggest you get a level and make sure the stove/oven is level and if it's not, there are some levelers ( where legs would be on the bottom ) that can be adjusted with needle nose pliers or a cresent wrench. If this doesn'e work, you may have some hinges sprung and need to replace them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Hitachi 50V500
Turn off your set. ( wait for the light and the fan to shut down) push and hold the Input button on the panel, power it on with the power button on the tv, as soon as you see the service menu appear, let go of the input button. Scroll down to : LCD adjust, toggle blue button to the right, another screen will appear. Adjust the squares on the screen until the ghosts are gone. hit Exit twice::Ghosts are Busted!
Aug 02, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Building Materials Logo
752 people viewed this question
Top ReliaBilt Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a ReliaBilt Building Material Expert? Answer questions, earn points and help others
