Question about Viking VWH3048 Kitchen Hood
Need a new fan switch
How do you get to the switch
I need a 3-speed fan switch for a Holmes stand fan #HASF1522
Just a thought
If you find a junker fan try the switch off of it. Quite often they will work. Sometimes different makes the switches are interchangeable.
Jan 31, 2015 | Holmes Products Dryers
SVFP30 "S" floor fan needs new switch
I don't think you can fined any parts these days for any small appliances as price part would be higher than price on new fan
Dec 09, 2013 | Dryers
Encon fan with two seperate switches. Switch works fan, but switch doesn't work light. I replaced wall switch, it didn't help.
Make sure the fan light wire is connected in the ceiling otherwise you might need a new pull chain for the light.
Nov 09, 2013 | Encon Industries 72200 PRESTON ES Ceiling...
I need to replace the pull chain that controls the blade speed for my Hampton Bay ceiling fan. I do not know the model number, but it is a 52" five-blade fan.
If the chain is broken off at the switch, you will need to replace the entire switch. It is not difficult to do and you can purchase a new switch from either Lowe's or Home Depot. You''ll find the switch in the ceiling fan department.
All you need to do, to remove the switch is remove the bottom cover of the fan housing, where the switch is located (if you have a light kit, you will need to remove it). This will give you access to the wiring and the switch. The switch is held in place by a threaded retainer ring on the outside of the fan housing. Unscrew it and push the switch back into the housing, Disconnect the wire nuts and totally remove the switch. Take it with you, when you go to purchase a new one.
If the chain is still visible by at least 1" all you need to do is purchase a new chain (usually comes with connector) and connect the two together.
As always, be sure the electricity is turned off to the fan, before attempting any repairs.
Hope this helps solve your problem.
Mar 02, 2011 | Hampton Bay Heating & Cooling
(93645) Ceiling Fan: Replacement fan switch...
Hi .. you can get a generic replacement ceiling fan switch at Home Depoot or Lowes. Look in their light section, where they have the lamp parts. Please do not disconnect the old switch before you have the new one. Then you need to know what wire does what on the old one and transfer it to the new one.
May 03, 2010 | Dryers
Ceiling fan stuck on high.
The fan usually has two holes for separate switch control. See if there is another hole on the opposite side that a switch can be added for separate control. Then go to the hardware store and buy fan switch with pull chain. Ask for help finding them, they have them in the special switch section of lamp parts. Install new switch (es) and wire the one the way it is. Add the new one and take the light or fan wire out from the old switch and put it to the new switch.
Sep 08, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Aloha Breeze Ceiling fan M# 29081, Fan Switch Problem
call 1-800-295-4448
you need a switch from them the internal mechanism is different. its free of charge
Nov 14, 2008 | Aloha Housewares (93645) Ceiling Fan
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Panama 5 12444T
try to replaced the dimer switch with new one.
Jan 19, 2008 | Casablanca Fan 74U9D Four SeasonsĀ® III...
Viking VWH3048 Kitchen Hood Logo
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
