Question about Primera Technology Primera Bravo Pro Xi2 Blu-ray Disc Publisher 2 Drives 63739
Unable to communicate printer even though printer is setup & installed
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
Tip
I get error 'Unable to find destination PC-Check the PC' on Kyocera Mita
Hi.
This error means that there is a communication problem between the printer and the computer that is receiving scanned file. The error is usually prompted on network installed printers.
Check to ensure that the Scanner File Utility software is running and the computer is able to receive data.
Try restarting the computer and printer. Disconnect both units from power supply for five minutes before restarting.
Check if you have firewall or security software active on computer that can block communication from scanner. Ensure that the scanner utility is listedas an exception on firewall settings, if the application is not present, then you need to add it to allowed applications list.
Ensure that you have granted Scanner Utility access to system resources if asked.
Reinstall printer software and driver on PC. This can be done either using the disk provided with the printer, or using the download from Mita website.
Test the computer network cable. If cable is worn it can cause communication errors. This problem is usually occurring on LAN (network) printer installation. If using local installation via USB, then test using a different USB cable. If USB cable is damaged or too long (over 10 m.) , then you may get the error stated on local installation.
The most common reason for this problem is firewall settings or network problems. Network problems may be difficult to troubleshoot. Remember also that there is a built in firewall in the router resident software. If the router is set to block inbound communication from printer to computer, or if printer and computer are in two different IP ranges (eg. 192.168.1.xxx and 192.168.2.xxx), then you may get communication between computer and printer blocked by router firewall.
Here a setup manual (click to download), also ensure that you have performed scanner setup correctly.
Here also Kyocera Mita download driver page:Kyocera's managed print services .
Regards.
on Mar 31, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Hp officejet 4355 and DV6300 VISTA laptop. unable to install device driver for printer
Manually unzip the files and right click the setup.exe nd select "Run as Administrator" Vista and 7 are notorious for requiring this even if you are the administrator account.
Jul 13, 2012 | HP Officejet 4355 All-In-One InkJet...
Unable to print from imac even it had been installed successful and the green line showing on wi
Try to print the wireless network settings page on your Lexmark X4650 to determine if your printer is still registered in your wireless network. 1. Press Setup (pattlnk_632008_2048-x4650stup.jpg) on the printer operator panel. 2. Press the right or left arrow button until Network Setup is displayed, and then press(pattlnk_632008_2052-x4650ok.jpg). 3. Press pattlnk_632008_2052-x4650ok.jpg at Print Setup Page. 4. Press pattlnk_632008_2052-x4650ok.jpg when prompted to Load Paper. 5. Press pattlnk_632008_2052-x4650ok.jpg. The network settings page will now print.
Check the IP Address and the SSID (network name).
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
May 09, 2011 | Lexmark X4650 InkJet Printer
Can not go wirelesss,using then install disc s300-400 seies
Just you need to do first uninstall the printer and setup again. If you are installing for the first time. Make sure that the printer is connected to the computer through a USB or any communication cable.
Even make sure that the router for internet is turned on and is set for public discovery. Some time we set it up as private and your printer will not recognize it as it cannot detect the connection.
Routers sometime have a small button on the back which says WiFi or other such option, you may even have to reset your router by pressing a small button on the back.
When you retry the to setup printer make sure you have installed all he drivers from the CD.
Thanks,
Bhautesh.
Aug 20, 2010 | Lexmark Multifunction Wireless Printer/...
I am running Vista Home 32 bit and have a Lexmark X4850. It will not communicate with the printer from either wireless or USB. I got it to print a test page from both, but that was one time after a...
Have you talked with Lexmark Technical Support? I suspect you may have to escalate this beyond level one. Vista on Mac is likely to have issues that differ from other Vista environments.
Sep 24, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Sharp dm 2010 Unable to connect printer function.
you may need to tell the installation program that you are connecting via serial port. Com 1 usually.
Jun 21, 2009 | Sharp DM 2010 Laser Printer
Unable to setup communication between cellular phone and laptop.
i had the same problem. when i installed the usb driver i got that message too. but after this i installed pc studio 3 and with the phone explorer it worked for me.
Mar 01, 2009 | Cell Phones
Primera Technology Primera Bravo Pro Xi2 Blu-ray Disc Publisher 2 Drives 63739 Logo
108 people viewed this question
Top Primera Technology Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Terry Hair
Are you a Primera Technology Computer and Internet Expert? Answer questions, earn points and help others
