Question about Samsung S1050 Digital Camera
My camera will mnot switch on
The display wont turn on
Canon 450d lcd will not turn on at all, viewfinder says busy, and camera will not take pictures
In menu option C.Fn-12 you can choose to switch the display off (or on) when you switch on the camera. The display stays off even if you switch of and on the camera.
Press the button <DISP> and switch off the camera, while the settings for recording are on the screen. After you switch on the camera, the LCD screen will be switched on again.
Please refer toy your english manual, I had to translate, because I don't have the English version.
Nov 20, 2013 | Canon EOS 450D Digital Camera
Won't switch on. Display - switch off camera and turn on again.
This is in a service loop and will not stop until the unit is repaired,
Jan 20, 2013 | FUJIFILM FinePix S2500HD Digital Camera
Pics. wont upload to computer no disc
if your camera has a switch for display or camera modes, then you may have to switch it to display mode to view the pics on your computer with the usb cable. When the switch is in the camera mode it will usually try to install it as a web cam and won't show any pics.
Sep 26, 2010 | VistaQuest VQ-5115 Digital Camera
Turn on the camera, no display, but it still takes pics
I have a Canon digital camera and can turn on an off the display. There should be a button in your Sony do activate the display. Cheers
May 23, 2009 | Sony Cameras
The camera wont turn on
hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
Apr 04, 2009 | Kodak EasyShare C743 Digital Camera
Display won't display anything, it merely turns on backlight.
This means the display has failed and a replecement at reasonable cost is unlikely. Check Kodak our for a repair But you wont like the answer I fear
Aug 08, 2007 | Kodak EasyShare DX7440 Digital Camera
No image
Try using a small pin to trip the micro switch that is located at the top of the card door. This switch is a little dodgey if it doesn't make correct contact the camera will turn on but the screen won't display. Did it woth mine and worked after that.
Apr 01, 2007 | Canon PowerShot A75 Digital Camera
LCD wont display when opened
It's either a broken position switch or more likely a torn ribbon cable. It can be fixed by any competent dhop that services Sony cameras.
Aug 26, 2006 | Sony Handycam DCR-DVD403 DVD Camcorder
Samsung S1050 Digital Camera Logo
16 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
