Question about Sun Netra 240 Server
PSU @ PS0 has FAILED. error
While attempting a system backup and error repeats not allowing the backup to complete. The error is PSU @ PS0 has FAILED. There is a system maintenance required LED lit up.
    Master:
  • 791 Answers
You haved answered on your own
Posted on Aug 18, 2014
Tried to run a full system backup with FreeAgent Go. Backup failed and it looks like some files and programs were deleted from my computer in the process.
Unless you asked the backup program to delete files it won't. The program may have deleted some files it created for its own use.
What error code did it give for failing the back up. How do you know you need the deleted files?
Mar 17, 2014 | Computers & Internet
System error hpdesignjet 1050c error 09B300 007A0EED
09Bxx0 errors relate to hdd read fail,#
there are two causes for this -1) the Hdd has indeed failed
2) the power supply in particular the hdd power supply(part of the main PSU) has failed- easiest way to see is connect a diferent hdd to the machine and see if it spins up if it does replace the hdd if it does not then replace the psu
Oct 11, 2013 | HP DesignJet 1050c InkJet Printer
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
Back up error.....i need more help please
check out this link for the solution.
http://www.pagestart.com/win7br0x8100003301.html
Dec 28, 2011 | Acer Aspire AX3400U2022
I have had two failed backup attempts and my d drive has only 19% free space. I have attempted a backup with disk should I purchase an external hard drive and if so how much memory should it have
A hard drive needs at least 15% of free space at anytime to allow it to shuffle files around so this is really the only reason for your failed backup attempts. And yes an external USB hard drive is a great idea and seeming i can buy a 500G for $110 or a 1000G for $120 i know which one i'd be buying. Cheers from Scott and please dont forget to vote
Jul 15, 2010 | Compaq Computers & Internet
ERROR 1002
This error can occur during a system recovery, and choosing the backup option to an external hard drive. The recovery might stop responding, and an Error 1002 message displays.To resolve the error, follow these steps:
  1. After the error message displays, turn off the computer.
  2. Disconnect the external hard disk drive.The backup is still useable.
  3. To continue the system recovery, restart the computer.
  4. Press F11 repeatedly at startup.
  5. Select Advanced Options , and then select System Recovery .
  6. When given the choice, choose to continue without a backup.
  7. After system recovery is complete, restore files from the external hard disk drive.
Jul 04, 2010 | Dell Dimension 8200 PC Desktop
Error 0x8007045D - cannot transfer data - I/O device error
try deleting all restore points before attempting a system full backup. the system is protecting this area on the drive from being copied deleting the restorepoints will allow backup remember to re enable system restore after, do this by disabling system restore temporaraly while preforming backups.
Dec 22, 2009 | Televison & Video
Dell Inspiron 1525 Blue screen & windows error messages/reformat
Do a recovery first and if you are still getting a blue screen on this 1525 call dell and ask for a replacment do not go any further in trying to repair it yourself as anything you do would just make matters worse if its out of warrenty then the only thing you can do is try:
1. clean the unit if there is any dust
2. try new memory modules
3. run a memory diagnostic on it using windos diagnostics
4. recover the operating system.
I hope you have some good luck with this advice.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Dell Inspiron 1525 Notebook
System State Backup problem
That specific error pertains to "validating" your copy of Windows. you might want to validate that copy, then re-try system state.
~~Jasta~~
Mar 24, 2008 | Microsoft Windows Server Standard 2003 for...
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
Sep 12, 2005 | Palm Treo 650 Handheld
Sun Netra 240 Server Logo
121 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
