Question about Medion MD 30262 32 in. LCD TV
No picture or sound
Cant tune my tv in it wont tune to any other ariel in the house neither is tv broke?
Blue screen tv that wont tune into any channels,tried different Ariels nothing works
Tuner fault. It is irreparable. Replace it with same number. Contact any service technician. http://electronicshelponline.blogspot.com/
Oct 28, 2014 | Televison & Video
Why wont my tv tune in the digital chanels using just an Ariel, its a Grundig about 6 years old.
Unless you have built in freeview then you won't be able to receive digital channels. Sounds like that's the problem here.
You'll need to buy a separate freeview box, you can get a basic model for ~£20.
Mar 01, 2011 | Televison & Video
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
No signal on my goodmans xpro freeview on the flat screen it says
hi there the first thing i would make sure you have a wide band ariel capable of receiving free view if the ariel is old and was there before you moved in and you have been there a while theres a good chance that the ariel isn't a wide-band ariel,
also check here with your post code to make sure free view is transmitted in your area
http://www.freeview.co.uk/availability
if you know you can get it and you have a wide band ariel make sure all connections are secure and that you don't have many leads connected together because you will lose a vast amount of quality though many leads to a point where you wont get a picture also make sure its the only tv on the connection as having a few will also do the same thing. ariel boosters can make a massive improvement on the line these can be bought any where even you local asda/walmart, make sure you have one secure connection right to the ariel socket to your tv. this eliminates any other problems
make sure you have your tv tuned in right if you have just moved house you will need to rescan for Chanel's as they can be on different frequencies from where you last lived
I hope this helps you if you Need a maual for your set please leave make and model number from the back of the set and ill try and get u a online manual for this set
Good Luck Hope You Sort It
Feb 03, 2009 | Archos AV 500 400-Hours Video Recorder
I HAVE A SAMSUNG LE40R7, I CANT GET DIGITAL CHANNELS ON IT ?
I TAKE IT YOUR WATCHING YOUR SKY BOX OR CABLE ETC THOUGH THIS TV..BUT YOU CANNOT NOT GET FREEVIEW..CHECK YOUR ARIEL PLUG GOING INTO THE BACK OF THE TV, THEN TUNE THE TV IN FOR DTV. NOT CABLE OR SKY ETC THEY WILL NOT NEED TUNED IN..THE MENU FOR DTV..IF THAT DOES NOT WORK..DO ALL THE OTHER TVS WORK OFF THE SAME ARIEL ON THE ROOF TO GET FREEVIEW ???
Nov 14, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Sound
First I would check the cable from the ariel to the tv and all connections in between.
May 15, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
Hyundai hqp-421*r/501*r
Hi gomaniac,
May i know how your plasma tv fuzzy as? Can you provide the photo to easily us measure it? May be you can go here to let me know which type of display problem are you appear?
http://www.fastrepairguide.com/plasma-tv-pdp-information/how-to-describe-explain-the-plasma-tv-problem-or-sym.html
May 09, 2008 | Hyundai ImageQuest HQP421SR 42 in....
Medion MD 30262 32 in. LCD TV Logo
16 people viewed this question
Top Medion Televison & Video Experts
Raj Patel
ray gallant
Are you a Medion Televison and Video Expert? Answer questions, earn points and help others
