Question about Maytag Dishwashers
Model no. WQP12-9319 instructions
Wats the digital readout for ,next to the clock symbol. Is it a temperature readout?
  • 244 Answers
SOURCE: Digital clock on LG electric stove doesn't display
buy new clocl display/circuit board
Posted on Mar 13, 2009
EllaWatson25
  • 725 Answers
SOURCE: the digital clock display doesn't show a readout,
You can save a lot of money by replacing this part yourself. It is a simple repair and we provide part removal/installation instructions whenyou get your parts through us.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7PM CST Monday through Saturday and we will get the correct part out to you asap.
We hope to get you cooking again, soon. Thanks, Ella
Posted on Jan 22, 2010
oldTech2332
  • 2341 Answers
SOURCE: The actual temperature of my
Press bake and set temp. to highest setting on some it's 500 on others it's 550 aftef setting to highest bake setting. Press and hold bake button until 00 is displayed,use up/down arrows to adjust in 5 degree incriments to plus/minus 35 dergees . ONce you've adjusted it push cancel/off button and you adjustment will be stored even if power loss and clock went out.
If your temp is more than 35 degrees off the clock needs to be replaced
Posted on Aug 16, 2011
  • 6771 Answers
SOURCE: clock readout indicates power, but nothing else working
In most cases it can be traced to the audio output ic as the problem, because part of the B+ is fed back in the radio. There is a remote chance a fuse has blown located near the ic.
Posted on Mar 05, 2012
dekdunn
  • 3 Answers
SOURCE: I have inherited a hifisonic
Buy another Brand with Instructions
Posted on Jul 04, 2012
My outdoor temperature shows three lines I have change the battier as manual said, but it didn't help? Do you sell replacements?
Fixya does not sell anything. The replacement batteries in the outdoor unit could be defective or installed incorrectly. The battery replacement procedure in the instructions must be followed exactly, i.e., batteries replaced in the outdoor unit then allowing time for the outdoor unit to begin sending data before installing batteries in the indoor unit to get an external temperature readout.
Oct 09, 2014 | La Crosse Technology Ws-8418u-it Atomic...
Can't get outside temp on my atomic clock
If you still have the instructions read up on pairing the transmitter to the clock. You'll need to do that every time you change batteries on the outside transmitter. If you don't have those instructions , go to the clock's web page to get the manual for your model of clock.
Sep 23, 2014 | Home
On model PLEF398DCH Frigidaire Professional Series electric range, my digital readout for the right side burners works fine. My left side digital readout is inoperative, but the burners work fine. Is there...
Good Afternoon Lee,
I understand that the left hand side digital readout is not working on your Frigidaire range, model# PLEF398DCH. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Once you restore power, you will need to set the clock and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Kitchen Ranges
How do you use it
--- SCANNED INSTRUCTIONS ---
CLOCK AND DATE SETTING: 1. Press and hold MODE button for three seconds. The minutes display will begin flashing. Press MODE button to switch among minutes, hour, 12/24 hour, month and day. 2. Press ADJ button to set value of the minutes, hour, 12/24 hour, month and day. NOTE: Original screen will return after one minute of inactivity. To view the date, press ADJ button.
ALARM CLOCK SETTING: 1. Short press MODE button to switch from clock to alarm clock. 2. Press the ADJ button once to make the D))))) symbol appear, which will indicate that the alarm is on. Press ADJ button again and a bell symbol will appear, indicating hour notification signal is on. The hour notification signal
sounds once at the top of every hour. Press ADJ button again to activate alarm clock and hour notification signal, press ADJ button again to clear all.
MEMORY FUNCTION: 1. Press the MEMORY button for maximum temperature and humidity to display. Press MEMORY button again for minimum temperature and humidity to display. Press MEMORY button again to return to current temperature and humidity. 2. Press and hold MEMORY button for three seconds to clear maximum temperature, minimum temperature and relative humidity.
COMFORT DISPLAY: When temperature remains between 68F to 82F (20C to 28C) and the relative humidity remains between 50% and 70% "COMFORT" will be displayed. When relative humidity is above 70% "WET" will be displayed. When relative humidity is below 50% "DRY" will be displayed.
FAHRENHEIT/CELSIUS: To switch between Fahrenheit and Celsius, press FAHRENHEIT/CELSIUS SELECTOR button on back of unit.
INSTALLATION: 1. Use provided suction cups to position the sensor probes in the terrarium. 2. Position THERMOMETER & HYGROMETER in desired location outside of terrarium with a built-in stand.
BATTERY TYPE: 1 PC Button cell (AG13/LR44)
WARNING: Install THERMOMETER & HYGROMETER and sensor probe out of reach of pets and away from water.
For more information about All Living Things products, please call 1-800-806-7870.
Dec 24, 2013 | ALL LIVING THINGS Digital Thermometer &...
We just moved into new flat with a whirlpool oven Model No: 6AKP524/1X. There's no manual. What are the 4 buttons on top/front for.
Unfortunately we are unable to offer assistance to those residing outside of the United States. Please visit http://www.whirlpool.com.au for assistance in your region.
Jun 09, 2017 | Whirlpool Ovens
The digital clock display doesn't show a readout, you have to guess what the clock and oven temperature are.
Jan 19, 2010 | Kitchen Ranges
Complicated
Do you or have someone in your area that read spanish?One thing you can try is to type it wor for in the computer and most compter can change it to english.
Mar 11, 2009 | Water Heaters
Air Conditioner for Benz 1998 E320
Check system for codes;
Displaying & Reading Trouble Codes (DTC Memory)
Air Conditioning (A/C)
Models 208 as of MY 1998
Diagnostic trouble Code Memory [15]
Note:
  • The A/C pushbutton control module (N22) has DTC memory and data output. The diagnostic trouble codes and data are displayed via the temperature display window. The stored DTC's will remain in memory even with the vehicle battery disconnected.
  • The DTC memory differentiates between current and intermittent faults.
  • Numerous DTC's can also be read with the Hand-Held Tester (HHT).
Preparations for DTC Readout
  1. Review 11, 12, 13, 14, 15, 21, 22, 31, 31, 41
  2. Ignition: ON
  3. Temperature selector: left: "HI"; right: "LO"
  4. Ignition: OFF
  5. Ignition: ON
  6. Within 20 seconds press REST and EC simultaneously for more than 5 seconds.
  7. The LED in Recirculated Air flashes and the display shows "d1A".
  8. Press AUTO repeatedly until all DTC's are displayed. Record each DTC as it is displayed.
  9. Each fault (short circuit, open circuit) is assigned a DTC. Thus in the left display: "E1" appears, and the right display indicates the DTC. The current faults (refer to table) are displayed first, next, the intermittant failures (e.g. 45 °5) are displayed in the display window next to the FAN symbol. By pressing the right AUTO the next DTC is displayed.
  10. To erase: Can only be performed after all faults have been readout. Press left AUTO and right AUTO buttons simultaneously for more than 2 seconds and the display shows: left: "d" and right: "FF". To cancel erase: By pressing the left AUTO button, the current faults will appear again.
  11. Select a base temperature setting.
  12. Turn ignition OFF, to end test.
Note: Due to instrument cluster (IC) series interface, DTC's may be stored in IC memory, therefore readout and erase DTC's from IC memory.
133090425133090426
Aug 20, 2008 | 1998 Mercedes-Benz E-Class
Reset self timer
hello,
the thumb wheel next to the lcd controls the self time on the left there is a symbol with a clock sign on it press it one a clock symbol appears on the lcd , this indictes that the time is on!
now depress the shutter button, after 10 seconds the snap is taken.
hope this helps
Mar 18, 2008 | Panasonic Lumix DMC-LC33 Digital Camera
Dishwashers Logo
13 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
