Question about Kitchen Ranges
ERROR CODE: F1E0 REPLACE OVEN UI
After spilling a very small amount of water near the front seal, I heard the panel beeping. Nothing could be done, even turning OFF. We tried unplugging it, cleaning and nothing is working? Your opinion? Thank you very much
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
F1 E0 Error
EEPROM communication error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Posted on May 01, 2014
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: Kitchen Aid range: error code F1E0 replace oven UI
F1-E0 = EEPROM communication error
3. If code re-appears, replace control board (also called ERC or clock). If you bought this control board used I am afraid it is bad. That error is only for a bad control board.
Here is a new board you may purchase. It is a little expensive but the supplier has a 365 day, any reason, any part return policy and you can be certain that you have a quality part.
Posted on Nov 13, 2012
How can I fix this?
Hello. There is an LE error that means "fill error". There is also a "tE" error that means "sump thermistor failure". You are probably getting the tE error--the thermistor is located at the bottom front of the washer tub in the center. If water is leaking from the bellow(the rubber part that seals tightly against the door), it might be spilling down onto the thermistor wires, shorting it out. With any leak, this will be an INVOLVED repair. My suggestion is to call for service--to reach anything in the front of the washer internally, the front panel must be removed--this is complex, and must be done carefully, especially if the bellow is leaking and needs to be replaced. I hope I helped you!
Aug 21, 2015 | Maytag MAH2400A Front Load Washer
Our Dishwasher (ESL63010) stopped working near the end of a cycle and wouldn't restart, three beeps (contact service engineer). Removed the front panel and found a fair amount of water in bottom tray, have...
Check for food in the trap filter. There shouls always be a small amount of water to expand the seal to prevent this and if the dishwasher is used unfrequently this may be a cause. You might need a new gasket. Just gotta love working on your back with water leaks it just makes my day.You can change the whole sump assembly but that's a lot of $$$.
Jan 04, 2015 | Dishwashers
Nov 10, 2012 | Kitchen Ranges
I have a microwave problem. My KitchenAid Convection/Microwave oven is showing error code "F6 E0" on the display screen. This occured after power lose and restore.
Hi Kent:
F6 E0 means that you are having a Lost Communication Error between the appliance; unfortunately this is the worst error code you can get on this model because there is no way to test for which part is definitely bad. You'll need to uninstall the oven and remove the top panel and the left side panel. make sure the wires are secure going from the interface control board to the program manager board on the left side of the oven. If it checks good, you'll need to make a guess and just replace one of the control boards because one of them is bad and you can't test to see which one is faulty.
Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic mode and verify the error codes. Ensure AM software, UI software and EEPROM CHECKSUM versions appear on the lower text line. If AM software and EEPROM versions do not appear, UI and AM may not be communicating. Verify this for the lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show the AM software version for the lower oven appliance manager, and the microwave UI will show the AM software and EEPROM versions for the microwave appliance manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions, go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between P6-1 of the appliance manager and P2-1 of the user interface board. Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to P2-5(UI). All the measurements made should be less than 5 ohms. If any of these measurements exceeds 5 omhs, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least 1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance manager has already been replaced.
- If both are replaced the problem has been repaired.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 10, 2011 | KitchenAid Washing Machines
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
manager.
EEPROM VERSIONS.
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
1 minute.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
Control panel quit working.
I guess it just dried out. A couple of hours later the panel began working again. Strange. You would think it would be sealed so that spills, etc. couldn't get in there.
Sep 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Error code F1E0 AND Replace UI ???
F1-E0 - EEPROM Communication Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 29, 2009 | KitchenAid KESC307 Electric Kitchen Range
Err F1E0 Replace Oven UI
The part CNTRL-ELEC solved our problem. The warranty repair person replaced it and it has worked fine for a week now.
Aug 24, 2008 | KitchenAid KEMC378 Electric Double Oven
No power
Any hope you may have left other than an expensive repair, is to remove the battery and leave the unit in an airing cupboard for a week and pray. Then replace the battery and try again. No change - then nothing lost. I know it's basic, and best done as soon as the damage was done, but has worked for me in similar circumstances. Don't be tempted to use a warm oven.
Jan 08, 2008 | Toshiba Portege M400-S5032X Tablet PC
Kitchen Ranges Logo
231 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
