Question about Dell OptiPlex GX270 PC Desktop
I am building a computer fron a gx270 tower the problem is the board actrs like it is sleep mode
  • 98 Answers
Did you replace it with its upgrade or the exact
same board,some voltages differ but it has to be the same eqiviant to.
Posted on Jun 15, 2009
My Dell optiplex gx 270 tower's chipset heats up and system shuts down and my friend's gx270 mother board is burnt due to same reasons
check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
May 06, 2012 | Dell OPTIPLEX GX270 (Y1057) Motherboard
Gx270 tower mother board amber LED solid on
If the fan is not spinning this can be the issue ...but it can also be the motherboard itself ..if you have the possibility try to change the fan ..cause if it fails to start the computer will also fail cause the cpu it will shut down the system instantly if it has no cooler working ..(gets to the shut down temperature in one sec or so ) If it seams that it is trying to start ..but , like I said , it shuts down ..just try to change the fan ...but it may be a issue with the power supply or the motherboard as well...
Dec 18, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
Hi,.. I was given a compaq FP 7317 with the tower, key board,...monitor keeps saying "going to sleep" when I finally got it all pluged in. HELP. HOW TO GET OUT OF GOING TO SLEEP?
To disable sleep mode in vista follow the steps
Go to start and type in the search box Power Options hit the enter button
On the Left side there is a panel Click Change when the computer sleeps
Click the drop-down box which says Put the computer to sleep and select Never
Click Save changes
Jun 28, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
Accidently pushed Zz button at top of key board Screen went black what now??
Sounds like you've put your computer into sleep mode. Hitting Escape or clicking the mouse will usually bring it out. Otherwise just tap the power button one (on the tower, not the monitor) and that should bring it out!
Mar 10, 2011 | Computers & Internet
Sleep mode problem
hey , first go to same mode in ur PC by pressing F7 .
thenblue window will appear so there select normal mode . thus ur PC will never go to sleep mode.
Jan 22, 2010 | Dell OptiPlex GX270 PC Desktop
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
May 24, 2009 | Dell Dimension 3000 PC Desktop
Sleep mode
I turned my power off from monitor and tower and turned them back on simutaneously with the F8 key. It worked.
Dec 17, 2007 | HP Pavilion F1703 17" LCD Monitor
Dell OptiPlex GX270 PC Desktop Logo
75 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
