Question about Dell 2.8 GHz Second Processor for PowerEdge 2850 Server (ND884)
Dell 2850 corrupted bios
At bios boot up I'm having an IP2850 corrupted bios that hangs at perc detection
proton77
  • 1183 Answers
SOURCE: dell gx280 sff show orange
Kindly follow the troubleshooting link below
http://tinyurl.com/c6uq8w
Thanks
Proton
Posted on Mar 12, 2009
luis356
  • 53 Answers
SOURCE: corruption exists!System halted?
you have a bad memory stick.
Posted on Jun 03, 2009
  • 110 Answers
SOURCE: Can ubuntu be installed on dell poweredge 2850
yes Ubuntu can be installed in Dell poweredge 2850 server
Posted on Oct 30, 2009
  • 11 Answers
SOURCE: my dell optiplex gx520 has
the reason why windows won't reconize it as a boot drive is because you have to format the harddrive to NTFS. You have to connect it as a secondary drive on another machine and format it. To do this you have to
click on start, right click on 'computer' and click on 'manage'. Once on 'computer management' click on 'disk management' and select the disk you want to format, right click on it can click 'format'.
Hope this helps.
Posted on Mar 20, 2011
nicarta
  • 506 Answers
SOURCE: URGENT. Dell Poweredge 2850 Mirror
If you know the two drive that are the OS mirrored drive, remove the failed drive and replace it with the good mirror drive and boot the system. If the drive and the OS is good the system will boot from that drive. You can now mirror this drive with a good disk.
Posted on Dec 01, 2011
Why the hard drives are not detected, and when accessing controller from the BIOS no hard drive found only DVD drive ?
You need to access the PERC system at bootup.. Much easier to use a SATA HD and not use the PERC controller.
Aug 04, 2014 | Dell PowerEdge T420 Server
I am having a problem with my dell poweredge 1800, it beeping continuous
Assuming this is still an issue...old as it is...
You need to boot the server and press the correct prompt to enter the BIOS of your PERC RAID controller. There you need to manage your physical/logical volumes.
Chances are that either you had a drive failure or the metadata on your RAID volume (JBOD?) was corrupted. This is a common issue with these LSI-based PERC[5-6]i RAID controllers that Dell utilized.
Jan 18, 2014 | Dell PowerEdge 1800 Server
Windows 2000 server fails to load,
Even if the scan says all ok I suspect bad sectors. To confirm try making images of the drives.
If you are able to get good images you can try raid reconstruction software.
If you need help I would suggest http://FreeDataRecovery.us they offer both online data recovery and do-it-yourself data recovery
Sep 13, 2012 | Microsoft Windows 2000 Server
I have Dell PowerEdge 2550 Server. I want to configure RAID, but I can't reach RAID MENU! I have DELL 2550 Server BOOT CD and Dell OpenMenage Server Assistant V7.2. All of them are running, but I...
RAID menu will either be CTRL-A (if you are using the onboard PERC 3/Di) or CTRL-M (if you are using an addin PERC 3/4). If you are not seeing either of these options, then you may not have it enabled in the BIOS. In the BIOS (F2), go to Integrated Devices and make sure that RAID is Enabled. In order to enable RAID, your server MUST have a RAID key, RAID memory DIMM (different from system memory), and a RAID battery.
Aug 12, 2010 | Dell PowerEdge 2550 Server
Wont boot says array controller wont start and no bios dell power edge 2500 server
Sounds like the RAID controller has failed. I would replace this first as RAID controllers are less expensive than replacing the system board, or the server as a whole.
Suggested: PERC 5i (RAID 0/1/5) or PERC 5iR (RAID 1 or 0 only)
Jan 03, 2010 | Dell PowerEdge 2500 Server
Dell Poweredge 4300 will not boot up after cmos battery replaceme
Configure your System bios and reboot. Your Hard disk drive was not configured. Pl configure. it will work properly
Aug 22, 2009 | Computers & Internet
Window instolation bootig files for hanging
Refix your RAM also check your hardisk is properly detected in bios .
Load optimal defaults settings in bios.
Aslo try with other bootable disk some times disk corruptation create this problem.
Jul 23, 2009 | Intel Motherboard
Format a dell latitude cs laptop
hi rashmi
first g o to bios setup and check your external dvd is detected .
If not detected in bios then enable legacy 2.0 in bios advanced option then go to boot option and save first as dvd drive.
then uc an boot with it.
Let em know
May 29, 2009 | Dell Latitude CS Notebook
Replacing bad hard drive
Can you explain more about what you are trying to do?
Is this a RAID configuration?
Is it SCSI or SAS or something else?
Thanks!
-Chip
Nov 04, 2008 | Dell PowerEdge 2600 Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Computers & Internet Logo
Alun Cox
