Question about SWANN Home Security
VIDEO LOSS ALL 4 CAMERAS SAY VIDEO LOSS
Power died at dvr will not power up. Screen says video loss and then goes black
The video loss is telling you that there is no video, so this is to be expected. When you plug in the NVR, does it power up at all? If not, it could be a power or cord issue. Check that out first and then check with Swann if you have any warranty.
Jun 23, 2015 | SWANN H264 8 Channel Dvr W500 Gb Hard...
SWANN PRO 642 AND VIDEO LOSS
make sure that the camera has power connected
Jul 10, 2014 | SWANN Pro-642 Indoor/Outdoor Security...
VIDEO LOSS ON ALL 4 CAMERAS
Check the power supply for all the cameras, most likely your power supply for the cameras is defective.
Mar 25, 2014 | SWANN Home Security
Our cameras were unplugged and then reinstalled (only partially uninstalled) and now we cannot get them to "reboot" We are getting an error of "video loss" I can not figure out how reboot the cameras so...
If your monitor is showing 'video loss' on each of the eight camera windows then the problem lies between the camera connections on the back of the Recorder and each camera. Without knowing what partially uninstalled means the troubleshoot process would be:
1. Use a voltmeter and check the camera power supply(s) line adapter where it splits to feed the cameras for full voltage- your unit should show 12Volts DC. Lack of voltage here and the cameras will not have power and cause 'no video' to the recorder.
2. Check the recorder menu to make sure that all camera inputs are turned on and are set to record. 'Covert' or hidden screens may not be viewed on a monitor but might show 'loss of video'.
3. It's highly unlikely that all cameras would fail at the same time so 1) if there is power and good video cable connections at the cameras, the next check would be to : 2) check each video connection into the back of the recorder and make sure that they are on camera "input", and not on a 'loop out' terminal by mistake.
If the above checks do not determine the fault, you would have to somehow feed a known good video signal into one of the camera inputs on the recorder and then troubleshoot the recorder.
If you repost what you have confirmed working we can re-assess.
Jan 25, 2013 | Night Owl Optics 8 CHANNEL H264 DVR WITH 8...
DVR Video Loss
Charter was out and changed modems, after that I noticed we lost signal.
Aug 16, 2012 | QPS Q-See QSDR008RTC-500 8 Channel H.264...
3 of the 4 camera's on Lion 4500 stopped working all at once. They say video loss, any suggestions
honest answer, a rat chewed through all my cables ran in my in one day. but sometimes I do lose random cameras during continuous record mode.
Jul 15, 2011 | Night Owl Optics 4 CHANNEL H264 DVR WITH 4...
Video loss
you're right... it is indicating video loss. from my experience, at least 90% of the time it's because the cameras aren't getting power.
Jun 11, 2007 | GE SDVR-16 Video Recorder
Home Security Logo
19 people viewed this question
Top SWANN Home Security Experts
Electro Med Services...
L Pfaff
L Pfaff
Da Doc
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
