Question about Tefal Actifry Fz700015 Low Fat Electrical Fryer 1kg Capacity
Plug socket has broken
Prongs from internal power socket have detached and fallen into the actifry I need to open the actifry to rectify but dont know how
How do I put my Kenwood KM262 back together, can I get a wiring diagram?
Is it the little plate with blue + blue + red wires? If so, it looks like a speed sensor and should be mounted somewhere near the rotor.
Maybe this will help (see page 17):
http://forum.adepem.com/depemdocs/KENWOOD/KM262%20demontage.pdf
Jan 25, 2015 | Kenwood Food Mixers
Have to know how to open joytab
Use a rubber same as to remove iphone screen. Lift screen out opposite end to all the side switches. When screen removed it gives access to power board.
Dec 04, 2012 | Tablets & eReaders
I bought a new tefal actifry family Ah9000 and when open the box and connect it to power then pressed on/off button nothing happened. Just a green screen with hardly to see sun shape on the left side
Use the timer. Unlike the Actifry and Actifry Plus models, the timer on the Actifry Family controls the fryer, and turns it off at the end of the cooking time.
Jul 20, 2012 | Tefal ActiFry Deep Fryer
SELECT button does not work
Sounds like an internal loose connection. Must have happened if it had fallen down from you. If you are patient and careful, you can repair it yourself. Else don't go for it as it can damage more keys. Just open the remote set and you will find what had been detached from where it should be.
Apr 17, 2010 | Yamaha RAV-270 Remote Control
How do i take it apart to get to the power prong?
Opening a computer is dangerous if you are not familiar with repairing computers.
If the power prong went inside the computer it means it is broken and detached from the motherboard where it is micro welded. I would recommend that you take the computer to an authorized Acer dealer.
Aug 25, 2009 | Acer Aspire One AOA150-1405 Notebook
The slot for the power input isn't working. how do i fix this?
I've seen this before on other laptop models. The cause of those have been that the internal power socket has become detached from the motherboard. This is not easy to fix, most repairers will recommend a replacement motherboard which can be expensive. Ask around, if you can find someone who does any electronic soldering they may be able to open the laptop up and reconnect the internal socket for you.
If, however, the laptop is still under warranty take it back and it should be repaired for you for free (my son did this with a laptop bought through PC World).
Hope this helps.
Aug 19, 2009 | Acer Computers & Internet
I have a kenmore dryer model 11060212990, and the plug has three prongs, but the wall socket is a four prong. what do i need to do?
You will need to purchase a 4-prong power cord and convert the appliance to meet the needs of the wall receptacle. This is a requirement of the National Electric Code in homes that have the 4-prong receptacle. The following link explains how to convert your dryer cord from a 3-prong to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
These rules apply to the conversion of electric ranges, as well. Read through the link thoroughly and let me know if you have questions. If you require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Dryers
Wiring problem
The wire you have is designed to carry 220 volts. Assumming that your socket is a 220 socket and that is what your application is the following answer applies. The black wire goes to one of the straight prongs and the red wire goes to the other. The white wire goes to the tight angle prong and The ground wire goes to the ground screw. good luck
Jan 17, 2009 | Midwest Electric 30-Amp Power Inlet Box -...
Power Supply
I would to make sure all the power plugs on the inside of your computer are snuggly secured. Also check to make sure the RAM sticks are plugged in correctly and that the processor is present and in place.
Aug 27, 2007 | Computers & Internet
Tefal Actifry Fz700015 Low Fat Electrical Fryer 1kg Capacity Logo
88 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
