Question about Casio GzOne Ravine 2 Phone Verizon
Error message usb dumper
Phone wont turn on
Power went out... when came back on got the message "error loading operating system"
While at this message remove any USB storage devices plugged into the computer (Cell phones, USB thumb drives, external hard drives) also eject any CDs and Floppies. Turn the computer off and back on. If the issue persists then it is possible that the power failure damaged a physical component of the computer.
Nov 13, 2012 | Lenovo IdeaCentre K210 - 53132BU PC...
Phone wont send text messages. the error message says [general error] code:[107] class:[1]
hey.try turning it off then taking the battery out after that put the battery back in turn it on and have someone send you a message. usually works for me. it could be your service area. thats normally what i do in this case and it helps.
Dec 12, 2010 | Kyocera X-tc Cell Phone
Data cable error message
please give me data cable error number
Jul 26, 2009 | LG Dare VX9700 Cell Phone
My phone has an error that say device error 400 reset. it wont even let me use it or nothing
When adding, deleting, or updating applications on your BlackBerry smartphone, you receive the following error message:
Device error 400
OR
your BlackBerry device resets itself and stops responding.
CAUSE
An unspecified error has occurred with an application on your Blackberry smartphone.
RESOLUTION
NOTE:The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Jun 11, 2009 | RIM BlackBerry 7290
Pcstudio 7 wont download on my laptop
Have you got pcstudio 3 on your laptop? If so remove all Samsung studios. Download the latest pcstudio 7 from Samsung plus USB driver. Put the USB driver on FIRST followed by pcstudio7 then it should work.
Mar 23, 2009 | Samsung SGH-i8510 INNOV8 Cell Phone
I am unable to connect my Samsung SGH 600 to my PC
sounds like you need to uninstall the software, reinstall it and then connect your phone.  If you are usng the front USB panels, try the back ones.  Sometime the front connectors are USB1 and are not fast enough.
Mar 06, 2009 | Samsung SGH-G600 Cellular Phone
Error message
Format your mobile! sometimes it may happen because of virus in your mobile!
Jul 06, 2008 | Motorola Mobility RAZR V3
USB
the phone has to be unlock correctly for it to erase that error msg
Jul 01, 2008 | Motorola Mobility RAZR V3
Bootloader USB INIT
i dont have a solution but my phone has the bootloader usb init screne too what did you do exactly to make it go away cause i already took out the battery but it wont go away.
and the unable to charge thing may be a charge cord problem
Jun 14, 2008 | Motorola Mobility E815
Battery Charging Error - Disconnect Now error message
Most new phones allow charging with the USB cable. With some phones, you also have the option to select whether you want to allow USB charging. If you're trying to charge with USB, make sure that your phone supports USB charging and that the option is switched on. please check ur settings..All the best
Happy to help
Have a nice day!
tc
May 30, 2008 | Sony Ericsson W850i Cellular Phone
Casio GzOne Ravine 2 Phone Verizon Logo
29 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
