Question about Cnet CWR-854 Router
Security key for wireless
Setup security key
Forgot security code
Are you speaking about wireless network security code?
You will need to open the setup page of the router and check the wireless settings of the router.
On the setup page you will find the wireless network key.
See How to find wireless network key
Mar 11, 2012 | NetGear WGR614 Wireless Router
Where is my network security key
My friend,
You have to lo-gin into the router setup page .
1.Put this address (192.168.1.1) in the address bar and then you will see the router setup page.
2.Then this will ask you for the username and password.
3.Username is nothing so leave this blank and password is admin.
4.Then you will see the router setup page .
5.Click on the wireless Tab under the basic wireless settings you will see wireless security .
6.Click on the wireless security and you will see there your router wireless security key.
7.Always select Security Mode as WPA2 PERSONAL.
8.If you want to change the security key you can.
9.After changing the settings Click on the sav settings.
Regards:-
Amit Awasthi
Dec 09, 2010 | Linksys Wireless-G WRT54G Router
I am setting up a wireless printer and it is asking for my wep security key for my router
Log into your router to get into the setup. Then go to the Wireless Security section. The password/key that you picked is there..
Read and follow this, When in the setup page for Wireless, you should see your security (WEP) key:
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=cfb50c0dc992443ab2405a782cca60f7_19073.xml&pid=96&respid=0&snid=7&dispid=0&cpage=search
Dec 01, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
How do I get my security key for my new laptop?
By Security Key, you mean the WEP/WPA Key that you entered when you setup the Router?
Use your browser and access the Router. Login to the application that is on the Router and look for your 'key' on the menu dealing with your WEP/WPA setup. That should be your key.
Also, get your SSID info as well, so you can setup your Wireless Network Card so it can 'see' your wireless network.
Hope that helps.
Nov 22, 2010 | Linksys Wireless-G Broadband Router
I have forgoton my key words
If you forgot your password, we can actually access the router web ui.
Accessing the Router's Web-based Setup Page
Step 1: Open your web browser.
Step 2:Enter your router's IP address on the address bar and press the Enter key.
NOTE: The router's default IP address is http://192.168.1.1.
Step 3: The Enter Network Password window will then appear. Type your router's User name and Password. Click OK afterwards.
Web-based Setup Page Wireless Security Options
On the web-based setup page, you'll be able to see all of your router's wireless security features. Wireless settings wherein you can see your network name and once your click wireless security sub tab under wireless page you will then see your network key or password (passphrase).
Nov 05, 2010 | Linksys Wireless-G WRT54G Router
How to remove a router security key from a DIR-655 D-link router?
Please follow the below steps to remove the security key from your wireless router DIR-655.
1. launch "Wireless Security Setup wizard". by clicking on setup.
2. Click "Next" , You will get a screen giving you an option to select the security level.
3. There you can select "None - No Security". & click on "Next & then click on "Save".
This would remove your security key from your wireless router.
Regards
Oct 11, 2010 | D-Link DIR-655 Wireless Router
How do i find the security key
You will need to access the setup page of the Linksys router to get the wireless security key.
On a wired computer's browser, type 192.168.1.1 in the address bar.
By default, leave the username blank, and the password is admin.
Once in the setup page, go to Wireless > Wireless security. You will see the network key. Take note of the key because this is your wireless security key to use on your wireless computer.
I hope this helps!
May 18, 2010 | Linksys WRT160N Wireless Router
How do i find my network key or create one for security?
Login to your router and check to see if wireless security is setup:
Use Internet Explorer and type 192.168.2.1 in the address bar.
Login using the password you created when you setup the router.
You can view the wireless security settings and retrieve the key.
If security is not setup you can enable it....directions here:
http://www.usr.com/support/5461/5461-ug/wireless.html
Mar 11, 2009 | U.S. Robotics MAXg USR5461 (738168036790)...
Wireless router hookup...
You need to use a working computer with the router then access the router setup page that way you can get the wireless security key, then follow this step:
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
When you're already on the Linksys router setup page, click on Wireless tab and look for a sub tab that says Wireless security and there you can find the security key that you're looking for..
Hope that helps..Don't forget to rate the solution FIXYA thank you...
Oct 04, 2008 | Linksys Wireless-G WRT54G Router
Cnet CWR-854 Router Logo
20 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Marcin
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
