Question about Cameras
Mist fan is leaking water
Leaking by the container
2 Suggested Answers
  • 1374 Answers
SOURCE: Heating AC problem
Either you need a heater core or the drain hose for the evaporator is clogged. Take it to a repair shop and have them check it out.
Posted on Jul 19, 2010
Sunbeam sul2512 humidifier leaking.
The Sunbeam SUL2512 Humidifier has three parts. From the top down:
Water tank
mist collar
Base unit
If the cap of the water tank (which contains a float valve) does not seal you may get excessive flow into the base unit which provides a working reservoir.
The base unit contains all the electronics including the cool mist transducer. This is a silver disk with a black silicone seal surrounding it. This is the only other place a leak can develop.
Mar 12, 2018 | Sunbeam Humidifiers
Why does my Sunbeam humidifier turn on but not work?
If the water valve from the water container to the misting head is defective, contains particles, or fails to open; then no activity will occur. Clean the system with Vinegar solution and be certain to use distilled or filtered water in the future.
Feb 05, 2018 | Sunbeam Humidifiers
Air Innovations cool mist humidifier model #MH-512- leaks water no matter what I do. Cleaned it. New filter. Keeps leaking. 2nd one I've had do the same.
The soft silicone gasket that fits around the container and base of the water reservoir must be dry, flat in place, and even all around to make a good seal. The unit must be LEVEL and not crooked or leaning in any one direction. If you have a leak, other than the gasket is a defect of the molded case or parts. If its within the warranty terms, return it for a replacement.
Feb 03, 2018 | Humidifiers
Stopped humidifying, water remains in the container. everything else seems to operate fine
If you are using the misting type humidifier rather than the wick-type. there could be a blockage in the misting aperture. These units clog easily, and it is best to use distilled water in them since mineral deposits can clog the aperture.
Feb 15, 2016 | Humidifiers
My car leaks antifreeze when poured into the reserve then it start leaking under the car on my 01 sebring
Would guess the container is cracked or a hose or pump is leaking
Take the container out if vehicle & check it over
May 08, 2014 | 2001 Chrysler Sebring
Plastic coolant container
The container may be cracked underneath.
Sep 25, 2017 | 1999 Mercury Mountaineer
Leaking washer bottle
Could be your pump is leaking or where pump goes into container,a rubber fitting is in the inlet and pump part goes thru rubber part to seal,it could be worn and leaking,you will have to remove container and pump to exam.
Nov 27, 2012 | Cars & Trucks
Water leaks from the plastic container into the well where the container sits
Locate where the leaks came and then apply epoxy to seal off the hole leaks. When it is done, test the unit in operation and observe if still leaks. If it gone then no more leaks, if it is still there leaks apply again epoxy. Not too much or not too little, just enough to fill the leak hole.
Thanks for asking.
Jul 09, 2011 | Vacuums
Heating AC problem
It sounds like the heater core is leaking engine coolant into the passengers side compartment. White mist could be steam from the hot coolant? The Heater fan could be damaged, or it is a short. Fill your radiator and take it to the shop or replace the heater core.
Jul 19, 2010 | 1997 Oldsmobile Cutlass Supreme
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
