Question about Electronics - Others
Picture not displaying in full
Bottom of picture at top, top of picture at bottom with black line separating.
SOURCE: nintendo DS bottom display screen
Hi I have a problem with my bottom screen as well. I was replacing the case as the hinge was broken. When i was putting it back together i noticed a slight tear in the ribbon cable which is attached to the board and the bottom screen.
When I turned it on I found I had poor colour and contrast in the bottom screen however the top screen was fine.
Where this ribbon cable is attached to the board there is two small cables attached to the board beneath it, maybe one of these has come away and needs repositioning or your bottom screen needs replacing.Try this site for diy tipshttp://site.powergamingparts.com
Cheers Chris
Posted on Oct 28, 2007
  • 208 Answers
SOURCE: Flat panel displays half screen, mirrored on bottom half of screen
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
Posted on Feb 03, 2008
SOURCE: Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Posted on Aug 17, 2008
  • 1030 Answers
SOURCE: screen lookes like colores separating
Hey try this check under setup do you have the convergence option. if you do not you may have a simple little repair. Check out the article in the tips and trick section of this site intilted "the fl231 problem"
Posted on Dec 06, 2008
t00nz
  • 4738 Answers
SOURCE: View finder screen has horizontal lines, almost
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Posted on Feb 09, 2010
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Some shows i don't get full screen picture about
You are watching a show or movie that was recorded in letterbox format, THIS IS NORMAL !
Jul 09, 2011 | Polaroid Televison & Video
Rca hdtv black screen at top picture at bottom
if you are talking about the picture looking like a 3-d picture, The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon.
http://www.fixya.com/support/r3342653-convergence_fix
May 04, 2010 | RCA HD52W56 52" Rear Projection HDTV
My proview 558 monitor has a 1/2 inch black line at the bottom
ms_biguns, You need to test one or the other, The tower should output and drive a substitute known good monitor, or a known good pc should be able to display the WIN-desktop screen on your Proview 558. Could it also be that the software in pc not set up for driving a Proview558? 12fixlouie
Feb 28, 2010 | Proview Computers & Internet
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Picture display format doen't fit 32'' screen
if you have cable box or a sattelite change the resolution of the STB to 4.3
Feb 06, 2009 | Sanyo DP32746 32 in. LCD Television
Aug 17, 2008 | Televison & Video
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Electronics - Others Logo
49 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
