Question about Honeywell Computers & Internet
Green led light is not on
The green led light is not on. does this mean the battery is full charged or is the led light bad
  • 132 Answers
SOURCE: LED Light on or off indicator
on my charger the red lights are only to tell there is power connecting especially when you have two battery's behind each other on the bottom of my charger there is a guide as to how long you should charge each battery as to size which are aaa 7hours max
aa 24hours
c 24hours
d 24hours
9v 24hours
hope this helps glenn............
Posted on Nov 22, 2008
SOURCE: Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Posted on Jun 06, 2009
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
my-mobility
  • 9 Answers
SOURCE: have a harsh jerking movement while using
This is a common problem often caused by the potentiometer(pot) in the centre of the Wigwag (Accelerator.) This part takes a lot of “abuse” and the pot causes an intermittent electrical connection resulting in a very jerky ride. Try spraying a contact cleaner spray in the pot but most often the potentiometer will need to be replaced by a technician. Regards Chris…
Posted on Jun 22, 2009
  • 115 Answers
SOURCE: Green and yellow light on charger; Battery does not charge.
check the terminals or wirings if it has detached,or its fuse,if after doing it you find out that your fuse is good,then your battery battery needs to be replaced
Posted on Oct 22, 2009
NIKON MH26 BATTERY CHARGER BLINKING GREEN LIGHTS
A blinking green light means the charger is charging the battery. A steady green light (same LED) means that charging is complete. If the light never stops blinking and we assume that your charger is working correctly, you may have a defective battery. Rechargeable batteries do not last forever. After a few years, there ability to take and hold a charge declines. It may be time to buy a new battery.
Apr 10, 2013 | Nikon D Cameras
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
CHARGING A COOL BATTERY PACK
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
When I charge a battery, the red light on the charger comes on but never switches to green and I dont know how long I need to charge each battery?
the green light or LED indicates or sign the the batery you are charging is already full,.so if it doesn't happen to switch ,it means that your baterry is weak and can not reach anymore the amount of current or amperes needed thats why it cant go to the highest peak of charging just like when it is new.Replace your batery and the green light will switch again if it is fully charge.
Nov 22, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Orange battery light on, but computer says its running on electrc
Hi, the orange light is meant to show a charging status, so if you have orange light and its running on electric it just means its plugged in and charging.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Same Problem
Hello, it was:
■ Charging LEDCharging LED
Or if the red LED remains on without turning green could mean a bad battery that no longer charges to 100% - get a new battery. Hope this helps
Jun 05, 2008 | Samsung Digimax i5 Digital Camera
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Blinking red light
What laptop brand and model is it? And where is the LED that blinks? Important details! Some laptops have a power light that blinks red while battery charges, then it turns steady green when battery is full. Some laptops have a red LED that lights whenever there is hard drive, CDrom, or floppy activity (read/write). This all depends on your laptop brand/model and where the LED is (side, near floppy/CD, top near screen, or on battery itself... so provide more details for me, please!
Nov 13, 2007 | Dell Latitude C640 Notebook
Computers & Internet Logo
51 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
