"no or bad signal" message on the screen
How to get rid of this message
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
How do i get rid of my no signal screen on my 37-Inch Vizio VX37L 1080i HDTV?
Simple answer would be to give it a signal! Does it show this message when you have a picture on screen? Check your connections and make sure they are firm to the plugs rather than loose as this may cause an intermittant signal causing the message
Oct 07, 2014 | Televison & Video
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
How do i get rid of "CHECK SIGNAL CABLE" on my 17" flatron wide monitor?
"Check Signal Cable" message is shown on the monitor only when their is disconnection between PC & monitor or if the cable is faulty. You can get rid of the message, which is built-in the monitor. Try changing the faulty cable.
sonsunny
Jun 28, 2011 | Dell Dimension 3000 PC Desktop
Hi sir i have nokia n73 and i there is screen problem with my nokia n73 on the top of screen (where signal and battery bars presents)there is an icon named 3G appearingand my phone will not be having...
3G simbol comes when we get rid of range,and if you want to get rid of that message goto settings>network>operator>network gsm only
thanks
Jul 29, 2010 | Cell Phones
How do I remove the Hd compatibility message from top of screen?
Go in ur tv menu go to Option go down the menu check the Program Title Dsiplay pick no.That should take away the HD signal sign.But some tv must have that HD sign,to tell u it in HD programings.
Apr 03, 2010 | ViewSonic VPW425 42 in. Plasma HDTV
When switching on the screen goes pink then blue and there is sound but no picture and a no signal message is displayed
A " no signal" message on the screen means that the set is telling you that it is not receiving a signal from whatever component you have hooked up to it in most cases. But the main be can be bad. The input connections are on the Main bd. Try hooking up another source(Component) to that input and see if you get a picture. If you do then yo either have a bad comoonent or bad cables. If you do not get a picture then your Main bd is probably the issue.
Jul 15, 2009 | Televison & Video
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
