Question about Cooking
What is the effect of the membrane of the frozen beetroot when the pigment is extracted
When 3 piece of beetroot are poured in test tube with 100ml of water
3 Suggested Answers
  • 75 Answers
SOURCE: Amana Model #TX20NBW FREEZES food in the fridge AND leaks water
Sounds as if the thermostat setting is too high.
Not a good idea to pour warm water into the fridge while its going, but then again.Most drain tubes exit over the compressor into a container sitting atop it. But I've since learned there are now fridges that don't have compressors now? You should also check the door seals, you can do this with a sheet/piece of newspaper
inserted between the door and fridge, go around both doors, you'll soon know if the seals need replacing.
Posted on Oct 03, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ice cube tray does not fill up water feeding tube is frozen.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valve and this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
Posted on May 25, 2012
GE Water Dispenser not working
Sounds like the water tank in the fridge section froze and split open causing a leak. Plus, the water feed line to the dispenser has frozen where it runs up through the freezer door- guessing your trimmer line only goes about 5" into the tube?
There is a water line heater kit that GE makes : Refrigerator Heating Element WR49X10173 .
Then, buy two quick disconnects 5/16" and about 10 feet of 5/16" plastic tubing- use the tubing and disconnects to replace the cracked water tank and you should be good to go... Refrigerator Water Line 5210JA3004K
Jul 03, 2016 | GE Refrigerators
If I connect plastic tube to back of fill tube shouldn't I be able to blow freely thru it? how do I remove the filler tube that goes thru back of frig to the icemaker?
Line to Ice maker is probably frozen due to long term "inactivity". I run hot water through a small flex tube and a plunger feed device or a Drugstore Syringe recommended by dentists to cope with tooth extraction. I used it for frozen dispenser line. It should work for your Ice maker fill line.
Mar 04, 2015 | Refrigerators
What are characteristics of chloroplast
chloroplast, structure within a green plant cell in which photosynthesis occurs. One of three types of round, oval, or disk-shaped bodies known as plastids, chloroplasts are distinguished from the other two types (colourless leucoplasts and yellow-to-red chromoplasts) by their green colour, which results from the presence of two pigments, chlorophyll a and chlorophyll b. A function of these pigments is to absorb light energy, which is converted to chemical energy during the process of photosynthesis.A chloroplast is ellipsoidal, about 2.5 microns (1 micron = 0.001 millimetre) thick and 5 microns long. The chloroplast is enclosed in a double membrane, within which are the stroma (a matrix containing dissolved enzymes) and the lamellae (internal membranes folded into closed disks, the thylakoids). These disks are necessary for the formation of adenosine triphosphate (ATP), an energy-rich storage compound. In the chloroplasts of most higher plants are regions called grana (singular granum), in which the thylakoids are tightly stacked.
Nov 07, 2013 | Computers & Internet
VDC Light stays on, then start to heats up
test the scanner and computer test for most effective result.
However see if fan/waterpump drive belt is slipping. Coolant is frozen
inlet or outlet water hoses are clogged or kinked. Coolant tube is blocked. Temperature gause is defective. Water pump defective. Fan is too far from radiator,(close it) .Defective water distribution tube. replace the tube. Fan insuficient blade are or pitch replace with large fan or with more blades.
God bless you
Jul 25, 2012 | 2001 Subaru Outback
Icemaker is not working
Pour about 2/3 cup of water into the icemaker . If those cubes freeze and dumps but water does not go into the icemaker , replace the water valve behind the refrig ( piece the water line connects to ) . If it does not dump the cubes , replace the icemaker . Also , check the fill tube ( tube which fills the icemaker ) to make sure it is not frozen up . If so , the water valve is seeping and still needs to be replaced . Check the coils under the refrig for dust , lint , pet hair , etc. The coils have to be clean for the icemaker to be 5 degrees , and work properly .
Mar 20, 2011 | Kenmore Refrigerators
How do you change the filters in a Culligan RO system
For a 4-Stage system:
1. Open the housing caps of the components that house both the sediment and carbon filters (you may need a residential spanner wrench). Put each filter into its proper housing and tighten housing caps MANUALLY. Do not use wrench.
2. Repeat process with membrane housing and membrane (if membrane needs replacing).
3. Remove inline polishing filter by disconnecting tubing at both ends. Replace with new inline filter and reconnect tubing.
Dec 30, 2009 | Culligan Under Sink Water Filter
HOw to replace Culligan water filters
Dec 18, 2009 | Culligan Under Sink Water Filter
Oct 03, 2009 | Amana ATB2135HR Top Freezer Refrigerator
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
Cooking Logo
76 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Are you a Cooking Expert? Answer questions, earn points and help others
