Question about Dryers
Wiring diagram three speed floor fan
How to wire floor fan with 5 wire?..where and what i connect the capacitor and the thermal fuse..and the L,1,2,3 connection
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
  • 66 Answers
SOURCE: four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Posted on Nov 12, 2008
SOURCE: Wiring the replacement 3 speed switch (fan motor)
I called King of Fans and the rep that I spoke with gave me the correct wiring for the 3 speed switch:
L White
1 Yellow
2 Blue
3 Black
The problem is that after I wired it this way I am getting the same result (off on 3 settings and a motor hum on 1 setting). So, either the Westinghouse switch that I bought at Home Depot is not compatible or it is the capacitor. The saga continues.
Posted on Feb 19, 2009
SolutionGuy
  • 331 Answers
Kalola,
You can if you want to, but it's not generally necessary. Here's a picture of a 3 prong configuration with a ground strap...
That green wire with the yellow stripe is a ground and it is most definitely connected to the cabinet somewhere. So it will serve as the ground strap (in the above picture).
Here's the thing... say you were going from a 3 prong to a 4 prong. That is, the dryer was originally "designed" for a 3 prong. This means you'd have to "retrofit" it a bit. Take a look at this pic... ( I made this for someone else, so please disregard my somewhat hostile remarks, OK?)
The ground strap has been removed and has been replaced by the ground to the frame. Yours probably does NOT have a ground strap, though... yours uses that Green/Yellow wire for frame ground.
All of that to say this. Don't lose sleep over it. Ya done good.
SG
Posted on May 02, 2009
Table fan winding&connection daigram
  • I have a Bionaire brand table electric fan.
    • It has a 3 speed fan motor.
    • The electric motor is a BM-122 Decomin brand 3 speed motor.
      • There are 6 wires:
        • Red wire.
        • Black wire.
        • White wire.
        • Yellow wire.
        • Gray wire.
        • Blue wire.
          • The motor has a 4mu 250volt capacitor.
  • This fan has an oscillating grill with independent sync motor, and timer circuit.
  • Something was wrong with the solid state circuitry (everything worked but the motor!), but a quick test of the motor indicated it does work.
  • The motor uses a start and run capacitor.
  • I decided to change controls to a simple mechanical switch and fore go for now anything beyond 3 speeds.
  • The printed circuit board shows the following connections:
    • Black wire
    • Blue wire
    • Yellow wire
      • Are respective for the:
        • High fan motor speed
        • Medium fan motor speed
        • Low fan motor speed
  • I think the gray wire goes out to the oscillator motor.
    • The Red wire is marked as Line, for the power source.
  • All wires are in continuity with each other EXCEPT RED is not with any other wire. How to Verify Fan Motor Wiring Connections
    • Checking the Motor and Capacitor Connections
    • Double check your connections using the fan wiring diagrams.
    • You should see that there is a separate motor winding for high speed.
      • The concern is that there is a capacitor for the motor.
      • So I'm thinking that the motor may have to start with the slower speeds first.
      • and not start in the high speed because the motor or capacitor has not been designed for that type of operation.
Sep 29, 2016 | Dryers
How do I reconnect the capacitor?
Not easy to explain. The capacitor is split, it has two values, or like two capacitors connected internally with a center tap between them. Two capacitance values, maybe 5uf and 20uf, the lower value for the fan motor and the higher for the compressor, with terminals C-common, F-fan, M-compressor.
Capacitor terminal C is the center tap and that takes 3 connections, line (power) - fan line common to capacitor, and Compressor line common to capacitor. Notice the fan and compressor have a power line not common to capacitor, just power line.
Capacitor terminal F has one wire connecting to Fan terminal C, fan may have three or four terminal writes, two for power with one power being common to capacitor connection and the other power alone, two power connection wire leads. Fan motor third line is capacitor, connects to the capacitor alone. Four wire configuration fan motor is not likely your needs. Omit or ask again for further explanation.
Compressor is similar to fan, only with a capacitance value higher than for tha fan motor. Two power leads, one straight power, the other power lead connects to the capacitor power. The third compressor lead connects alone to the capacitor.
The with is to draw a diagram and level the colors of each lead and terminal lavels too. The motors nameplate may indicate wire color code, the a-c nameplate wiring diagram may be present in the control wron wiring compartment, the goal is to find clues or to trace each wire and verify what they connect or do, take notes on your drawing.
Basically the motor has three terminals, L1 - L2 - C, or C- S-R (Common, Start,Run)
Jul 14, 2015 | Maytag Heating & Cooling
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
I was trying to install a fan control switch on my Patton floor fan and took the 3 speed switch out and disconnected the wires and cannot figure out what wires (too many colored wires) to connect to the 2...
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
Dec 28, 2010 | Patton U2-1487 Floor / Box Fan
I have a HV-20G floor fan, And I have no contitnuity between the "white"--(common ) wire and the"red-low", "blue-mid", or "black-hi" wirres.I have 7.3 ohms between the blue&black and blue&red on a...
In that particular model, there is a small thermo fuse connecting the white wire and the yellow wire(there are 2 yellow wires coming from the capacitor). It's hidden in the coil so you can just cut the wick in that area an pull those two wires and you are going to see the fuse(small square shape one).
Sep 14, 2010 | Lakewood HV 18-c Floor / Box Fan
Ceiling fan capacitor hook up problem. I have a 3 speed fan. 4 switch. A 3 wire capacitor - CBB61. Kids lost wiring diagram. Any which way I try to wire it up only one of the speeds works. Any wiring...
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
May 15, 2010 | Dryers
I'm looking to replace the fan switch for a hampton bay ceiling fan, but I don't know where the wires go. The colors of the wires are black, yellow, purple, and orange, and the slots on the switch are L,...
This is fairly simple.
Assuming you have a black brick capacitor, and assuming you have the correct switch, for capacitor speed control.... (if you don't you will not blow anything up)
On your capacitor, there should be a set of two wires which are the same color. Black goes to L The two wires which are the same color, one will go to position 1. The other two wires, will go to 2 and 3. On the capacitor it should have some numbers and crude diagram with the color of wire on it. The wire with the highest value (say it's 6) will go to position 2 and the lower value will go to position three.
If you only have one small capacitor in the switch housing, (usually a red and white wire one) then you have a winding taps speed control. If you have a capacitor type switch, you can burn out your motor, as on the second position of that switch it activates both 2 and 3 (or medium and low) Be sure you have a switch which operates as such L+1 L+2 L+3. If you have the proper switch, then all you need to do is connect the black wire to L and then randomly place the other three wires into the switch and test it. Most likely the speeds won't be right (it might go medium, low, high) if it does, then just move the wires around until it goes high medium low.
Mar 31, 2010 | Oasis Hunter 54' Ceiling Fan
Box Fan Termal fuse/capacitor> bypass
the thermal fuse is for safety reasons
The Lasko fan I have that stopped working needed the thermal fuse replaced
go to radio shack they have them
Aug 06, 2009 | Lasko 3720 Floor / Box Fan
RV AC, how to wire fan (blower) motor to capacitor.
You almost have it Look closer at the run capacitor. It has Herm, this is for the compressor, Com or C and F or Fan.
1 of your power wires is the fan speed so connect them accordingly usually black is hi, blue med, & red is low. You are "feeding" voltage to the selector switch on 1 side and coming out to the fan motor speeds.
Next you have a "Common" wire on your fan motor (this means its Common to all the other connections inside the fan motor to me. It is usually white. Connect this to the other line of power usually the Com on the capacitor unless it connects to a strip on the selector switch. But 1 of these 2 places will be the other side of your Power when plugged in. Lastly the brown it is usually the fan capicator only wire and it will connect to the fan "F" terminal on the capicator this terminal will not have any other wires connected to it.
This should make you a happy camper. Please rate me accordingly and good luck.
Mar 08, 2009 | Dometic Rooftop RV Air Conditioner
WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Mar 11, 2008 | Oasis Hunter 54' Ceiling Fan
Dryers Logo
130 people viewed this question
Top Dryers Experts
