Question about Rvinyl Performance Films Headlight Tint Film Vinyl Sheet Roll Wrap - 24" Light
Headlight tint removal
Removing tint from headlights
    Sergeant:
  • 266 Answers
Was the tint on the car when you bought it? Why would you want to remove it? If it's been added to the plastic lens you'll need to get a professional to remove it without scratching the plastic lens.
Posted on Jun 05, 2014
How to fix low beam headlights won't come on---hi beams work ok?
Kenneth, you need to give more details on what kind of vehicle, year, make, style and so forth so we can attempt to make a judgment on this.
Well did you try the solution?
Your headlights are an essential safety system for nighttime driving & visibility. If your headlights are not working, or are not aimed properly, you might not be able to see the road clearly.
Here are some suggestions on how to troubleshoot various kinds of headlight problems:
Problem: One headlight does not work
This usually means one of the headlight bulbs has burned out. Bulbs have a limited life that depends on the number of hours of use, and how much vibration they have been subjected to over time. The thin tungsten filament inside an incandescent headlight bulb will eventually burn out. The more nighttime driving you do, the sooner one or both headlights will fail. A typical automotive incandescent headlamp (halogen or regular) has a service life that may range from 600 to as much as 2000 hours of use. For the average motorist who drives 12,000 to 15,000 miles a year, that means replacing a headlight maybe every five or six years depending on how often the headlights are used. Driving on rough roads may cut that life short by causing the delicate filament inside the bulb to fail prematurely.
The Fix: Replace the burned out bulb.
But before you do that, inspect the electrical connector on the back of the headlight carefully for damage, and see that it is not corroded or loose.
The headlight bulbs on most vehicles today are changed from the back of the headlight housing. The housing is a sealed plastic shell with the bulb and socket mounted on the back. The socket that holds the bulb usually twist-locks into the housing. Rotating it counterclockwise about ¼ turn will unlock the tabs and allow you to pull the bulb and socket out of the housing. Access on some vehicles is easy, but on others you may have to remove other components that are in the way, or even remove the housing mounting bolts and remove the housing before you can change the bulb. See your owners manual or the vehicle service literature for detailed instructions on how to replace a headlight bulb.
Once the socket has been removed from the headlight housing, you can pull the old bulb out of the socket and replace it with a new one (must be the same size and style as the original bulb).
Aftermarket replacement bulbs with slightly higher wattage ratings and/or tinting are available to upgrade headlight performance and improve nighttime and bad weather visibility.
best regards,
daid
I ask you did you try the solution posted twice then?
Sep 28, 2015 | Cars & Trucks
Spray tint removal
use rubbing compound with a buffer
Mar 26, 2014 | 2004 Chevrolet Impala
Replace headlight bulb
  1. INSTALLATION GUIDE:
  2. BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
  3. Parts Identification:
  4. Projector Headlight
  5. Halo & L.E.D.
  6. Bottom of the Headlight:
  7. Ballast Bracket, Halo Wires(red/black)
  8. Turn Signal Adaptor
  9. TOOLS REQUIRE
  10. 10mm - 8mm socket
  11. Philip Screwdriver
  12. Crimper/Pliers
  13. For more information about how to install your vehicle, come visit our youtube page on
  14. http://www.youtube.com/spyderauto
  15. Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
  16. Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
  17. Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
  18. Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
  19. Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
  20. Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
  21. STEP:
  22. Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
  23. Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
  24. Factory Xenon Headlight
  25. Spyder Projector Headlight using Factory Xenon Lights
  26. STEP:
  27. PLS VOTE ME
BMW e46 HID Headlight Replace
Nov 23, 2012 | 2000 GMC Denali
How do I get to the front headlight to change it
Re: Replace headlight bulb
  5. Halo & L.E.D.
  9. TOOLS REQUIRE
  12. Crimper/Pliers
  21. STEP:
  26. STEP:
Nov 22, 2012 | Cars & Trucks
How do i change my headlight assembly on a 2001 honda accord
HEADLIGHT REPLACEMENT
1. Remove the front bumper
2. Disconnect the connectors (A).
3. Remove the 5 mounting bolts (B), then remove the headlight assembly (C).
Fig. 21: Removing Mounting Bolts & Headlight Assembly
Jun 24, 2012 | 2001 Honda Accord
Once I remove the nuts and bolts, I can't get the headlight to move
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative (-) battery terminal.
  3. Loosen the mounting bolts and nut of headlight assembly (A).
    Loosen the mounting bolts and nut of headlight assembly (A)-Santa Fe
    Loosen the mounting bolts and nut of headlight assembly-Veracruz
    Click to Enlarge
  4. Take care that retaining clip (A) is not to be damaged-Santa Fe.
  5. Disconnect the headlight electrical connectors.
  6. Remove the headlight assembly.
  7. Remove the headlight bulb:
    • Remove the headlight bulb(s) with a counterclockwise turn-Santa Fe.
    • Remove the headlight bulb after removing the bulb caps (A)-Veracruz.
      Remove the head lamp bulb(s) with a counterclockwise turn-Santa Fe
To install:
  1. Install the headlight bulbs.
  2. Install the headlight bulb caps-Veracruz.
  3. Connect the headlight electrical connector.
  4. Install the headlight assembly.
once bolts out lift up on the headlight unit hope this helps plz vote comment reply if you need more help
Jan 17, 2011 | 2007 Hyundai Santa Fe Limited
Need to remove and repair headlight motor on a 1988 corvette
REMOVAL & INSTALLATION 1984–88 Vehicles
  1. Open the hood, then turn the headlights on.
  2. Detach the headlight motor wire on the outer side of the headlight.
  3. Turn the headlights off (the disconnected light should stay open).
  4. Unfasten the 4 screws at the bezel. There are 2 at the front and 2 at the sides. Fig. 1: With the hood in the raised position, unfasten the Torx® screws from the outer side of the headlight bezel/trim piece 91036p23.jpg
    Fig. 2: You must then remove the screws from the inner side of the bezel/trim piece 91036p24.jpg
  5. Remove the bezel. Fig. 3: Remove the first of the top bezel/retaining ring screws . . . 91036p25.jpg
    Fig. 4: . . . then remove the remaining Torx® screw 91036p26.jpg
    Fig. 5: Lift the bezel/trim piece away from the headlight assembly 91036p27.jpg
  6. Remove the retaining spring by carefully using a hooked end tool, such as a cotter pin removal tool to move it to the side.
  7. Remove the headlight from the aiming pins by rotating the headlight toward the center of the car.
  8. Unfasten the 4 retaining ring screws, then remove the ring. Fig. 6: With the hood closed, you can see the 4 headlight retaining ring screws (1) and 2 aiming screws (2) 91036p28.jpg
    Fig. 7: Remove ONLY the 4 retaining ring screws, do NOT touch the aiming screws 91036p29.jpg
  9. Remove the headlight pump from the mounting bracket, unplugging the socket as you pull it away. Fig. 8: Remove the headlight away from the mounting bracket, unplugging the socket as you pull it away 91036p30.jpg
    To install:
  10. Install the headlight bulb, making sure it is plugged in properly.
  11. Position the retaining ring and secure with the 4 screws.
  12. Position the headlight into the aiming pins. Move the retaining spring back into place.
  13. Install the bezel and secure with the retainers.
  14. Turn the headlights on, then connect the headlight motor wire.
  15. Turn the headlights off. Both should lower.
  16. Close the hood. Check the aim of the headlights, and adjust if necessary.
1989–96 Vehicles
  1. Open the hood.
  2. Open the headlight door halfway. This can be done either by turning the headlight switch on, then back to the parking lamp on position, or by the manual headlamp control knob (which is located on the inboard side of the headlight door). NOTE: Before removing the screws from the side of the headlight bezel, place your hand under the bezel to support and prevent damage to it.
  3. Remove the screws from the front of the headlight bezel. NOTE: Before removing the screws from the side of the headlight bezel, place your hand under the bezel to support and prevent damage to it.
  4. Remove the Phillips head screws from each side of the headlight bezel.
  5. Remove the bezel by pulling it straight out from the engine side of the hood. Fig. 9: View of the headlight bezel mounting 91036g28.gif
  6. Unfasten the screws from the headlight retaining ring.
  7. Remove the headlamp from the assembly, unplugging the electrical connector as you are pulling it away. Fig. 10: Exploded view of the headlight assembly 91036g29.gif
    Fig. 11: Location of the headlight mounting and aiming screws 91036g30.gif
    To install:
  8. Attach the headlight electrical connector.
  9. Position the retaining ring and install the screws securing the ring to the headlight.
  10. Position the bezel in place on the headlight assembly.
  11. Install the screws on each side of the bezel and tighten to 51 inch lbs. (5.8 Nm).
  12. Install the screws on the front of the bezel and tighten to 17 inch lbs. (1.9 Nm).
  13. Cycle the headlamps, then close the hood. Check the headlight aim, and adjust if necessary.
Jul 07, 2010 | 1988 Chevrolet Corvette
How do you remove the headlight bulb
1. Remove headlight unit
2. Disconnect headlight leads
3. Remove bulb cover
4. Remove headlight bulb holder
5. Remove headlight bulb
6. Install new headlight bulb - DO NOT TOUCH THE GLASS PART OF THE BULB!
7. Install headlight bulb holder
8. Install bulb cover
9. Connect headlight leads
10. Install headlight unit
I'm not aware of any shortcuts, nor do I believe that any steps could be changed or eliminated without re-engineering the headlight unit.
Jun 06, 2010 | 2008 Yamaha Royal Star Venture
Headlight removal
1) Lift up on the headlight retainer to release the headlight assembly. 2) Release the headlight ball studs from the grommets by pulling the headlight assembly from the lower center corner. 3)Remove the headlight assembly from the upper fascia support. 4) Disconnect the harness connector from the headlight assembly. 5) Remove the headlight assembly from the vehicle. 6) Remove the access cover from the rear of the headlight assembly. 7) Remove the headlight bulb socket from the headlight assembly by rotating counterclockwise . 8) Remove the headlight bulb from the socket. Reverse these steps to install and make sure when your done to adjust the headlight.
Jun 17, 2009 | 2005 Pontiac Aztek
97 F-350 Headlight door removal
The front couple bolts (enough to fold the inner fender wells) on the fender wells (plastic part around inside the wheel well). Take them out, I think i did 6. Basically, just do what you have to do to fold the front part of that plastic inner fender well enough to see behind the parking light, then you need to remove the parking light/corner light assy. and once they are out you can reach the final screws required to remove the headlight trim rings. Also there are a few people on EBAY that are selling replacement headlight/parking/corner light assemblys that have clear outer lenses that dont get all yellow and foggy as the stock ones do. I bought smoked ones that have a light tint to it and they have projector caps so you can use HID kits and get a nice beam. something you might want to look into if your going to do the trim rings since its kind of a p.i.t.a.
Oct 15, 2008 | 1997 Ford F350 Crew Cab
Rvinyl Performance Films Headlight Tint Film Vinyl Sheet Roll Wrap - 24" Light Logo
63 people viewed this question
Top Rvinyl Performance Films Home Experts
john h
Tom Chichester
Are you a Rvinyl Performance Films Home Expert? Answer questions, earn points and help others
