Question about GE Furance Blower Motor 1/5 Hp 208-230v 5kcp39cgp874s
Thermocouple hard to remove on magic chef furnace
Hard to remove from holder, what do I do?
    New Friend:
  • 65 Answers
THEY EITHER HAVE A NUT THAT HOLDS THEM IN PLACE OR EARS THAT STICK OUT AND HOLD IN PLACE. IF EAR TYPE GIVE IT A PULL STRAIGHT DOWN IT SHOULD COME OUT
Posted on Mar 26, 2014
WHERE IS THE FUSE LOCATED ON MY MAGIC CHEF MCO165UW MICROWAVE
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 02, 2015 | Magic Chef Microwave Ovens
How do you adjust the pilot light flow on an old magic chef heating unit/ceiling mounted furnace?
How long is the pilot flame? It could be you can move the thermocouple into the flame by making adjustments of the metal holder. If the flame is small, there is an adjustment for the piolet flow in the control module where you turn gas on and off and light the pilot. It should be labeled and usually has a cover that must be unscrewed to reveal the adjusting screw. Need a bright flash light to see what you're doing.
Feb 28, 2015 | Heating & Cooling
I have a magic chef furnace, armstrong series if the pilot light and ignightor both work but the burners wont light is it possible the thermocuppler bad?
The thermocouple keeps the pilot light on. If the flame blows out it shuts off the gas to the pilot lite only the board that has the igniter on it supplies power to open the main burner as long as the igniter is operating. Sounds like the gas valve is nor working.
Nov 19, 2014 | Magic Chef Refrigerators
Magic chef furnace G66-100D-5
Go to magic chef.com get the manual
Nov 01, 2014 | Heating & Cooling
Have a 1986 Fleetwood Park Model with a Magic Chef gas oven that will not light. The pilot is lit but the oven burner will not come on. Uses propane gas...it worked last year.
Propane is a "dirty" gas. That can sometimes result in a particle of debris getting lodged in a pilot orifice, causing a low pilot flame. Inspect the burning pilot, look to see that the pilot flame encompasses the thermocouple so that the thermocouple may get hot enough to open the gas valve. If the pilot is too low, sometimes tapping on the pilot assembly with some handy tool will dislodge any restricting particles from the pilot orifice and restore flame size. Make sure that the pilot or thermocouple have not been struck by some object and knocked out of place. If the flame and thermocouple seem OK, you may have a bad thermocouple. Before replacing the thermocouple, loosen and re-tighten it's connecting nut at the valve (follow the thermocouple "wire" to find the valve) , if the connection is poor, sometimes that will restore good contact.
Also to note: the pilot will be at minimum when the control valve is "off", the pilot flame size should at least double when the control valve is turned on. Be careful, that is gas you are working with.
Feb 03, 2010 | Magic Chef Kitchen Ranges
I need a wiring diagram for a magic chef furnace
There should bee a wiring diagram on the inside door of the unit, it will show fan speed connections
Nov 01, 2009 | Heating & Cooling
I have an old Magic chef furnace and need to replace the Fan Motor were can I find the fan spec for replacement? It was built in 1987 Model # G8A75DC10-17 Serial# A 10221CKA Forced Air Furnace Categorie I
magic chef furnaces were discontinued many years ago. Pull the motor and take it to your local motor shop. They will be able to match it. Furnace blower motors are pretty standard fractional horse motors.
Oct 06, 2009 | Heating & Cooling
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
Jul 28, 2009 | Magic Chef Microwave Ovens
Magic chefa313-230lw gas ignitio
hi .thanks for the question . A very common problem with gas ovens replace the igniter thanks the appliance doc
Sep 29, 2008 | Magic Chef 9512 Electric Single Oven
Microwave
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
Feb 08, 2008 | Microwave Ovens
GE Furance Blower Motor 1/5 Hp 208-230v 5kcp39cgp874s Logo
27 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
