Question about Proscan 26LB30QD 26 in. LCD HDTV
Turns off Proscan 26LB30QD 26 in. LCD HDTVi turn it on works for awhile then turns it self off
Can I replace the Intel Celeron 420 processor on my EMCP73VT-PM motherboard with a duo core E8600 or is there a better inexpensive replacement?
Posted on May 11, 2014
  • 86 Answers
SOURCE: Need DirecTV remote code for Proscan 26LB30QD
Direct TV Remote Codes for various devices.
Posted on Feb 15, 2009
SOURCE: I can not remove the
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Posted on Feb 23, 2009
  • 814 Answers
SOURCE: surround will not work on proscan 26" flatscreen
This television has only one audio output. IT is a coax digital output listed as N on the back of the television.You will have to get a adaptor to use it with you portable surround sound. You Should be able to find one online. just google the type you need to the coax, and it should bring up places that sell them. If you cannot find one you can go to the PROSCAN website and use the customer support section to get help from them.You can also call them at 1-888-977-6722. It might be best to call them to make sure you get the correct adaptor for you use. I hope this helps you with your problem.
Posted on May 21, 2009
SOURCE: I need the remote control code for Proscan tv with dvd player
Don't know if the 26" is the same as the 32, but 10019 works for the 32".
Posted on Jan 18, 2010
Tv goes off by it self but i can turnit back on
Short circuited component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 26, 2014 | Proscan 26LB30QD 26 in. LCD HDTV
Tv goes off by it self can turn it back on
hi make sure the timer is not on , the other fault could be capacitor or a dry joint in the power supply ,i'd look for a tech in your area hope it helps
regards
shaun
26LB30QD DVD Player says
reinstal dvd software again then check
May 16, 2012 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 32'' VGA port; TV says not supported on VGA input
Sounds like your resolution on your computer is set too high for your tv to accept. Try putting your computer resolution down to 1024x768 or lower and see if that works.
Jul 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
How to turn off CC. Button says no info
Go into your menu under Audio, it should be there, navigate to turn it off.
Jun 15, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
How do your turn off the captioning of wat the people are saying on tv off i have a proscan hdtv
hello, just go to the menu and turn it off, normally says CC and gives you a few options including the CC off.
May 27, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Remote for tv
If your TV model number is 26LB30QD, it's $32.12 at remotes.com
Rate me if I answered correctly
Feb 02, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26LB30QD 26 in. LCD HDTV Logo
42 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
