Question about Emerson Televison & Video
Change screen resolution
I need to change the resolution of the television. The viewing area is only about 1/3 of the screen.
    Top Expert:
  • Emerson Master
  • 74,378 Answers
Adjust the aspect ratio. Refer its user manual for details.
Gopakumar Gopalan Google
Posted on Mar 26, 2014
Change TV resolutions to view slide shows
Nope. The picture resolution has to be 1080 to fill the screen completely. Using stretch and zoom will distort the low rez pictures. No option to change resolution on the TV itself.
Jan 23, 2014 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I have a 19in Emerson Flat Screen TV that I am using as a PC Monitor and it isn't using the full screen. How do I fix it to use the whole screen?
You might not be able to. If the screen size doesn't adjust with the wide/view mode/picture format button on the television remote control you have to change the resolution on the pc. You right click on an empty spot on the desktop, choose properties, and then choose the settings tab. A lower resolution will cause the image to fill the screen but the icons get really big. The image isn't as refined. However you may be able to play around with it enough to find a good enough resolution and a view mode with the Emerson remote that will work out for you (a combination of the two).
May 31, 2011 | Televison & Video
Hi All, I have a Compaq nx9110 notebook, can't set the resolution higher than 1024x768. Specifications I've found on various web pages say the resolution can be increased up to 1280 but I've...
hi
1.Minimize all applications so thatyou have a clear view of your desktop. 2.Right-click an open area of thedesktop - make sure you don't right-click an icon such as My Computer bymistake. 3.From the small menu that appears,click (left mouse button) on "Properties." 4. A "Display Properties"window will appear; click the "Settings" tab to bring it to thefront. 5.In the lower right portion of thattab, find the section titled "Screen Area" with a slide bar goingfrom left to right, or from "less" to "more." 6.With your mouse, slide the bar tothe right, towards the "more" side. As you slide the bar, youshould see the word under it go from 800 X 600 to a higher resolution, such as1024 X 768. 7.I recommend trying just one notch ata time. Click "Apply" to test your new settings. Aninformational message will appear, saying that you will have 15 seconds to testyour new settings before they take effect. 8.Click "OK" to test the newsettings. The screen will change to allow you to view it, and if you wantto keep those settings, click "Yes" within 15 seconds. To keepyour old settings, click "No" or wait 15 seconds. 9.Repeat steps 6-8 until you have asetting that you are satisfied with. When you are done, click "OK" tomake the Display Properties box disappear.
Tips:
1. Some video cards and/or monitors support fewer colors as the screen resolution increases. It is up to you to decide which is more important. The number of colors is to the left of the "Screen Area" section on the same tab. 2. Once you have your resolution set higher, try maximizing the window for various programs. You may be surprised how much of a spreadsheet or webpage you can view on your screen!
May 26, 2011 | HP Compaq Business NX9110 Notebook
I have a Polaroid 42" TV and the screen does not
if its a hd tv try viewing a true hd source and the grey areas should go away. you might have and resolution button on the remote that will toggle between screen modes. look for that button and give it a whirl and also make sure yoiu view a true hd program
Dec 24, 2010 | Polaroid Televison & Video
Can someone help me connect my Acer Aspire 3680?
Your graphics card on that should push that resolution so I would probably lean toward the tv. Try changing the aspect resolution or (zoom button) on the remote to change the way the screen is delivered. As long as the resolution on the laptop is a widescreen resolution and the same for the television. Make sure in your tv settings, that the aspect is set at 16:9.
Jan 12, 2010 | Acer Aspire 3680 PC Notebook
Screen Viewing size
Change the screen resolution on the laptop to 1024x768
Mar 30, 2009 | Sony VAIO VGN-FJ270/B Notebook
Picture is too large. How do you change resolution?
On your television press the menu button to bring up the on screen display. Use the up or down arrows to find the aspect ratio control. Press the right arrow button to change the screen settings. Set the television to the best setting for your viewing pleasure. Hope this helps you with your problem. If you need technical assistance you can call Insignia customer service at this number: 1-877-467-4289. Hope this helps you with your problem.
Mar 29, 2009 | Insignia 37" LCD Flat-Panel HDTV
Poor quality of viewing Photos, Online TV and Videos
change to screen resolution to 32 bit.
to do this, right click on any empty area on your screen, select setting and change the screen resolution, from 256 to 32.
Nov 04, 2008 | Computers & Internet
Blank area on both sides of screen
If you have it hooked up to a cable box, then you should be abl to change the resolution setting through the cable box remote control, if not call your cable provider to access the menu that does the resolution settings
Mar 02, 2007 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Televison & Video Logo
47 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
