Question about Air Intake Temperature Sensor
Were is the intake temperature sensor located on a mazda 2001 B3000
Were is the sensor located
  • 38 Answers
Posted on Mar 27, 2014
Mazda b3000 2001 heater works after one hour of running
That means your engine is not heating up to working temperature or if it is the water hoses that go to the heat exchanger unit are clogged. Confirm that you engine coolant is heating up to working temperature. If not you might not have a thermostat in your cooling systrm. Insert one. If that does not solve the problem check water flow to air con.
Nov 03, 2011 | 2007 Mazda B3000
Where is the camshaft position sensor located on a 1994 Mazda B3000
The Camshaft Position Sensor is located within the Ignition Distributor assembly, although removeable, it is not serviced separately.
Oct 10, 2011 | 2007 Mazda B3000
Where is the camshaft position sensor located on a 1994 Mazda B3000 2wd
  • It's mounted behind the rear of the intake manuifold in the engine block.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 10, 2011 | Cars & Trucks
I need a diagram of 2001 Mazda B3000 2WD firing order... i know the order. i need to see which order they are located on the motor
I hope this helps or at least you can see it as I have had problems posting pictures. If you can't see it just reply I will try to manually draw you a diagram. Good luck.
2001 Mazda B3000 SE Regular Cab 2WD
Feb 06, 2011 | Mazda B3000 Cars & Trucks
Firing order 2001 mazda b3000 3.0L v6
2001 Mazda B3000 DS Regular Cab 3.0 liter OHV V-6
Hope this helps (remember to rate and comment this).
Sep 22, 2010 | 2001 Mazda Pickup Regular Cab
I need a diagram of the exhaust system on a Mazda 626
0996b43f80203328.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Component Location Chart-2000 MPV
1 PCM 2 Mass air flow (MAF)/intake air temperature (IAT) sensor 3 Throttle position (TP) sensor 4 Fuel tank pressure sensor 5 Engine coolant temperature (ECT) sensor 6 Crankshaft position (CKP) sensor 7 Camshaft position (CMP) sensor 8 Knock sensor 9 Heated oxygen sensor (HO2S) (front, LH) 10 Heated oxygen sensor (HO2S) (front, RH) 11 Heated oxygen sensor (HO2S) (rear, LH) 12 Heated oxygen sensor (HO2S) (rear, RH) 13 EGR boost sensor 14 Power steering pressure (PSP) switch 15 Main relay
0996b43f8020330c.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Component Location Chart-2001 MPV
1 PCM 2 Mass air flow (MAF)/Intake air temperature (IAT) sensor 3 Throttle position (TP) sensor 4 Engine coolant temperature (ECT) sensor 5 Crankshaft position (CKP) sensor 6 Camshaft position (CMP) sensor 7 Knock sensor 8 Heated oxygen sensor (HO2S) (front, LH) 9 Heated oxygen sensor (HO2S) (front, RH) 10 Heated oxygen sensor (HO2S) (rear, LH)* 11 Heated oxygen sensor (HO2S) (rear, RH)* 12 EGR boost sensor
0996b43f8020330f.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Component Location Chart- 2002-06 MPV
May 22, 2010 | 2004 Mazda MPV
Can some one tell me where is Canister Purge Solenoid/Flow Sensor located in my 96 mazda b3000 truck? I have check engine light on, and auto zone guy give me this code P1443.
It is between the charcoal canister and the intake manifold. It is in a vac line, the same one as the canister purge solenoid. It real close to the battery. I might be able to post a pic if you can't find it.
Apr 06, 2010 | 1996 Mazda Pickup
I cant find the air intake temperature sensor
on some cars this sensor is located on the air box where your air filter is or on the tube that goes from your air box to the engine
Jun 12, 2009 | 1990 Mazda 626
Air Intake Temperature Sensor Logo
129 people viewed this question
Top Bosch Vehicle Parts & Accessories Experts
xxxxxx xxx
Rob Beech
Andrew Gaitan
Level 1 Expert
Are you a Bosch Vehicle Part and Accessory Expert? Answer questions, earn points and help others
