Question about HP LaserJet 1022n Printer
I tried to bt it can't print
When I treid to print it can't print so when I trid to run the setup it ask me a ipadress n the host name
    New Friend:
  • 78 Answers
Are you connecting through an ethernet connection? there is more information needed.it sounds like you are by the information that it is asking.Need to know what operating system you are running.If this is not in an office environment with more than one person printing to it you would be better off using local usb cable.
Posted on Apr 15, 2014
I am getting a 'disk full' message on the Fiery. How do I delete it?
TROUBLESHOOTING
This chapter provides troubleshooting tips.
Troubleshooting the Fiery
Startup diagnostics are described in the documentation for service technicians. Contact your
authorized service/support center if you see error messages while Command WorkStation is
starting or if the Fiery does not reach the Idle state.
Runtime error messages
For error messages related to canceling jobs and printing, including the Disk Full message and
alerts to load media, see Command WorkStation Help.
For error messages related to the copier, see the documentation that accompanies your copier.
You can turn on PostScript error reporting as a print option from Mac OS applications.
Printer not found
Most failures to find a printer on the network are due to conflicting or missing name or
address settings for the Fiery. You must type names in specific places. The required names are:
•TCP/IP host name (also known as the DNS name), which is defined by your organization.
Type the host name as the Server Name in Fiery Setup.
•Remote printer (internal machine) name. Use one of the following:
print
hold
direct
NOTE: If you change the DNS name (also known as the TCP/IP host name) of the Fiery, you
must reconfigure one of the utilities on each workstation. http://swdownload.efi.com/ftpvefigs/9019710383/2822679259/9432346727/7795362481/Configuration.pdf
Dec 12, 2015 | Xerox DocuColor 242-252-260 PS
Sandra4609g@btinternet.com
Every iPad should be capable of sending email. You first have to setup the account, in settings, then email, then add new account.
While entering a new account, you have to fill in all settings correct, so you need to know it it is a POP or SMTP server, you must fill in the complete and correct e-mailadres and server name and the correct password. if filled in and you press next, the program will check the validity of the address. Only if the address exists and the password is correct it will tag everything green. Then you can use the mail address. It must be an existing mail address. You can't create new addresses in that part.
I'm not sure if you are running the iPad on a G3 or G4 network from BT, because that firm can try to block other mail, to save bandwidth, but I don't believe that.
You should be able to setup the BT account. If you keep having trouble setting up the BT account, visit a bt store and ask them to setup your mail address
Jul 18, 2014 | Yahoo Mail
Network can't ping jetdirect 615n card
why not ask at HP and not here, why ask on non HP forum.?
the HP enterpise forum covers this.
ask here first., they will direct you to OLD hardware help.
https://h30434.www3.hp.com/
here im searching there, see all those posts there.
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=JetDirect+615N
Jun 08, 2017 | HP JetDirect 615N J6057A Print Server (In...
I have a KM 4050 and when we scan it is giving a "send error 2101" Everything else is fine. We are able to print from our computers etc. so I know our connections are ok. Any suggestions?
The following errors are simalir;
2101, 2102, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name correctly.
The link below takes you to Kyocera's Scan to SMB setup guide on GFBM's website (they are a Kyocera dealer). The guide setup guide is good and gives pictures and examples.
http://gfbm.net/Documents/self_help/SCAN%20TO%20SMB%20PC%20setup%20R3.pdf
I hope this is helpful,
Shawn
Feb 11, 2011 | Kyocera Copystar CS-1820 Black and White...
HP JetDirect J3258B asking for host name
Question is, if you DO type anything does it save then? I had a similar problem and the box was faulty. Having a host name in their won't stop it from working.
Dec 12, 2009 | HP Jetdirect 170x Print Server
How can i connect my bluetooth to my pc?
on pc side
1. give your host bt name
2. find bt COM port
My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
on phone side
1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
pairing
1. add device
host: go to My Bluetooth Places->Add new connection
phone: go to bluetooth, choose Paired Devices->add
2. provide passkey (4-digit, 0-9 only) on both
Check mRouter
check bt COM port that you found
Start bt serial
if you see mRouter turns green and blue, you got it
start pc suite
Oct 19, 2009 | Nokia 5000 Cellular Phone
Can't print using HP C6180 Printer via DG834G router
More information is needed to diagnose this issue:
- What form of wireless security setup do you have (WEP, WPA-PSK, etc)?
-have you gone through the steps (http://h10032.www1.hp.com/ctg/Manual/c00753538.pdf, Option B for the wireless setup) to be sure your printer matches these settings? Pay special attention to the section where it says to use the FIRST key in a multi-key WEP setup, and be sure the laptop is also using that key; WEP could be the issue if the laptop and printer are using different keys to connect.
-Did you give the printer a static IP address to request, or are you just letting it grab one dynamically?
-Have you tried installing the printer as wired rather than wireless, then printing from the laptop wirelessly?
Nov 09, 2007 | NetGear DG834G 802.11G Wireless ADSL...
Setting up 16 port switch
Dear This is the step You can get a complete home network up and running in 10 easy steps. Here's a summary of what's involved: Take stock of your existing hardware. If you wish to share an Internet connection using Internet Connection Sharing (ICS), choose which computer will be your ICS host. Decide what type of network technology you wish to use. Make a list of the hardware you need for each computer. Install the network adaptors and install your modem on the ICS host computer. Physically cable the computers together. Switch on all computers, printers and other peripherals. Make sure the ICS host is connected to the Internet. Run the Network Setup Wizard on the ICS host. Run the Network Setup Wizard on the other computers on the network. Let's take that step by step. 1. Take stock of your hardware Note each computer's location and its hardware, including peripherals such as printers and modems. 2. Choose your ICS host If you wish to share an Internet connection between your computers using Internet Connection Sharing (ICS), choose which computer will be your ICS host. The ICS host has a direct connection, either by dial-up modem or high-speed link, to the Internet and provides access to the Internet for other computers on the network. Ideally, the host should be a computer running Windows XP. I'll assume you have made this choice in the following steps. Apart from XP's easy handling of ICS, by using an XP computer as your ICS host you get the benefits of using the Internet Connection Firewall. 3. Choose a network technology The most common choices are Ethernet and wireless LANs. For an Ethernet LAN you will need to install a network interface card, or NIC, in each computer and run cabling between the computers. If you don't like the idea of opening your computer to install a network card, look for a USB adaptor instead. Depending on the size of your network, you may also need a network hub or router to provide interconnection between PCs on the LAN. Two PCs can get by using an RJ-45 crossover cable; three or more computers require a hub or multi-speed hub (called a switch). If you have a high-speed Internet connection, a high-speed router is a good option. The Network Setup Wizard includes links to detailed advice about configuring your network, including help on designing a network layout to suit your home. If you opt for a wireless LAN, you'll also need a NIC for each PC (there are versions which use USB adaptors as well). The big benefit for home environments is that a wireless LAN does away with the need for cabling. On the down side, though, wireless LANs tend to be slower, less robust and appreciably more expensive than traditional Ethernet LANs. In particular, wireless LANs do not always live up to their stated working range, and you may find factors such as your home's construction and design, plus interference from other devices affect your wireless LAN's performance. You may need to add an expensive Access Point to extend the range of the LAN and, even so, it may not be sufficient. The bottom line is, if you decide to go the wireless route, make sure the store will refund your money if the LAN will not provide reliable performance within the specified range. 4. Make a list of hardware needed Make a list of the hardware you need for each computer, not forgetting any cabling, and buy it. If you're a little dazzled by the choices and configurations, consider purchasing a networking kit. These kits contain all you need to set up a two- or three-PC network. If possible, look for hardware which features the Windows XP Logo, indicating it is fully compatible with XP. 5. Install the adaptors Install the network adaptors and install your modem on the ICS host computer (you can also let the computers connect to the Internet independently by installing modems on each). 6. Cable the computers Physically cable the computers (and hubs or routers) together. Of course, you won't need to do this if you've chosen to go the wireless route. If you're installing an Ethernet network and have a lot of cabling work to do, you may prefer to get a professional to come in and do this work for you. It won't be cheap, but you can be sure you get the job done correctly and hopefully with minimal damage done to walls, ceilings and floors. 7. Switch it on Switch on all computers, printers and other peripherals. 8. Connect the ICS host Go to the ICS host computer and make sure it is connected to the Internet. 9. Run the Network Setup Wizard on the ICS host To run the Network Setup Wizard on the ICS host, click Start -> Control Panel -> Network And Internet Connections -> Setup Or Change Your Home Or Small Office Network. Follow the instructions in each screen and press Next to continue. XP's Network Setup Wizard takes much of the pain out of setting up a home network. The Network Setup Wizard will guide you through: Configuring your network adaptors (NICs). Configuring your computers to share a single Internet connection. Naming each computer. (Each computer requires a name to identify it on the network.) Sharing the Shared Files folder. Any files in this folder will be accessible to all computers on the network. Sharing printers. Installing the Internet Connection Firewall to guard you from online attacks. 10. Run the Network Setup Wizard on all computers To do so: Insert the Windows XP CD in the first computer's drive. When the XP Welcome Menu appears, click Perform Additional Tasks. Click Setup Home Or Small Office Networking and follow the prompts. Repeat steps 1 to 3 for each computer on your network. Make sure you maintain an active Internet connection on your host computer as you proceed through this process. geekgirl.tip If you don't have a CD-ROM drive on one of the network computers, you can run the Network Setup Wizard from a floppy disk: While running the Network Setup Wizard on the ICS host computer, select the option to copy the Network Setup Wizard to a floppy disk. Once you've completed setup on the ICS host, take the floppy to the next computer and insert it in the drive. Double-click My Computer. Double-click 3½ Floppy (A:). Double-click netsetup.exe. The quickie XP network If you want a really easy networking experience and you have the hardware to support it, consider clean installing Windows XP on two or more computers. First install your network hardware (network interface cards, cabling, et cetera), then perform a new installation of Windows XP. During installation, XP will sense your hardware setup, ask for a name for each computer, and then ask which type of setup you wish to create. Select Typical Settings For A Default Network Configuration. That's it. Provided your hardware is XP-compatible, XP will create a LAN using the workgroup name MSHOME. Using your network Once you have your network up and running, you can easily access other computers on the network via My Network Places (click Start -> My Network Places). The Task Pane in My Network Places lets you access computers on your network and adjust settings. The Task Pane in My Network Places lets you view your network connections and view each of the computers in your workgroup (the workgroup consists of all computers on a network which share the same workgroup name ? by default, XP gives all computers on your home network the workgroup name MSHOME, although you can change this if you wish). When you initially open My Network Places, you'll see icons for the Shared Files folder of each of the active network computers. Sharing a printer With your home network installed, your PC suddenly gains all the advantages of the other PC's on the network. If you've been lusting after your sister's colour photo printer, you can now print directly to it from your own machine. Provided, that is, your sister decides to share her printer. (You might offer to let her share your laser printer in return as an inducement ? sharing works both ways.) To share a printer, on the computer which is directly connected to the printer: Click Start -> Control Panel -> Printers And Other Hardware -> Printers And Faxes. (Note: These steps will be a little different if you're sharing a printer on a PC running a version of Windows other than XP. For example, under Windows Me, you click Start -> Settings -> Printers.) Click the printer you wish to share. Click Share This Printer in the Task Pane. In the printer's Properties dialog, click the Sharing tab. Click Share Name and OK. Make a printer accessible to others on the network by sharing it. Once a printer has been shared you can access it from other computers on the network. To do so: Click Start -> Control Panel -> Printers And Other Hardware. Click Add A Printer. In the Add New Printer wizard, when asked whether the printer is a local or network printer, select the latter. In the next screen, select the option to Browse For A Printer and click Next. Select the appropriate printer from the list and continue with the wizard. Sharing files and folders Sharing a folder is even easier than sharing a printer: Open a folder (such as My Documents), click Make A New Folder in the Task Pane and name your new folder. With the new folder highlighted, click Share This Folder. In the Sharing tab of the Properties dialog box, select Share This Folder On The Network. Provide a descriptive name for the folder. This name should make it easy for others on the network to recognise the folder; it doesn't have to be the same as the folder name you selected in step 1. You can let other people on the network view and edit your files or view them only. If you want to protect your files from tampering, remove the tick from Allow Other Users To Change My Files. There are a variety of ways to access a shared folder. Here's one way: Click Start -> My Network Places -> View Workgroup Computers. Click the computer whose files you wish to access and then click the shared folder. You can create shortcuts to shared folders to make them easier to gdfgf
Sep 08, 2007 | Computers & Internet
Banner Printing
Hi Thank you so much for the best information wth banner design. i got my banner design method on here http://www.thewebpole.com/ @ from the domain name processing, with the free services of hosting, and mosr services like, * Photo Album
* Quick Blogcast
* Hosting with site builder
* Personalized Email Account
* Starter Web Page
* "For Sale" Page
* Parked Page w/ Domain
* Domain Forwarding & Masking
* 100-Pack Email Forwarding
* Total DNS Control
* Change of Registration
* Status Alerts
* Domain Locking
Jun 18, 2007 | HP Deskjet 6940dt InkJet Photo Printer
HP LaserJet 1022n Printer Logo
22 people viewed this question
Ben Johnson
