Question about Ac Delco Vehicle Parts & Accessories
I ordered AC compresor, accumulator, and clutch cycling switch I hace recieve my products exept the clutch cycling switch
I have recieved these products except clutch cycling switch.Can my mechanic replace the compressor and accumulator and charge the a/c system and replace the clutch sycling switch when it arrives?
    Problem Solver:
  • 6 Answers
There shouldn't be any trouble with having the cycling switch installed after everything else is installed and charged. The mechanic may need to temporarily bypass the switch to get the system to run in order to fully charge it, however the switch can safely and easily be changed on a fully charged system without compromising the refrigerant.
Posted on Apr 24, 2014
4 Suggested Answers
SOURCE: replaced ac comp. and dryer. had it charged and
Keep the fuse cartridge at 20 amps (OEM Specs) but you have to change the relay. That could have been the original cause to begin with.
Posted on Jan 17, 2011
sxygaman
  • 95 Answers
SOURCE: ac blows hot air
the ac clutch itself is bad there is a little washer in behind clutch sticking easier and almost as cheap to replace compressor
Posted on Aug 12, 2012
emissionwiz
  • 77169 Answers
SOURCE: ac on sx4 suzuki short cycles
You do not have enough charge in it, add 6 more ounces should do it.
Posted on Nov 05, 2012
2002 ford mustang air conditioner stopped working. How do I locate the problem?
FIRST I CHECK ALL FUSES AND RELAY.TO BLOWER MOTOR IF IT STOP BLOWING.AND CHECK FUSE TO HVAC SWITCH CONTROL.AND CHECK FUSE / RELAY TO AC COMPRESSOR.IF FUSE / RELAY GOOD POWER GETTING TO AC COMPRESOR CLUTCH COIL AND LOW PRESSURE SIDE 28 PSI AND HIGH SIDE 200 PSI. CLUTCH COIL IS OPEN.IF REFRIGERANT LEVEL LOW YOU MAY NEED MORE REFRIGERANT.YOU NEED AT LEAST 28 PSI ON LOW SIDE AND 200 - 220 PSI ON HIGH SIDE.IF ALL IS GOOD STILL NO AC PROBLEM COULD BE A FAULTY AC CLUTCH CYCLING PRESSURE SWITCH.
Aug 16, 2010 | 2002 Ford Mustang
Trying to recharge a/c unit with freonand can't find the charge recepticle
high side port just beside radiator on passenger side and low side port is located on the accumulator right next to clutch cycling switch
Jul 24, 2010 | 2001 Ford Expedition
My jag's a/c compresor froz up and now shop wast 1200.00 for change out and charge system. Is that all it will need jag X type 3.0
The AC is driven by a pulley pulled by the serpentine belt. When the AC is switched on an electrical clutch engages the driven pulley with the AC compressor on the same shaft. If the AC compressor is frozen up the pulley will not turn when the AC is switched on and the belt will squeal as it is pulled over the static pulley wheel. If, when the AC is switched on, the pulley wheel continues to spin then it is likely that the electrical clutch is not engaging. It is much more often the case that the clutch fails before the AC seizes. If this is the case check out the AC fuse and clutch relay. The fuse can be inspected visually and the relay can possibly be inter- changed with one that is similar (windscreen wiper or electric windows). The relay should make a 'click' that can be heard when the AC is switched on. Put the suspect relay into a circuit that you know is working in order to check it.
Jul 01, 2010 | 2004 Jaguar X-Type
A/C compressor went out. What else needs to be replaced along with it?
the AC system must be flushed out with an approved AC flushing solution, this is avail from any part store, u will need compressed air, then replace the AC accumulator/reciever dryer
Feb 12, 2010 | 2001 Jeep Grand Cherokee
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
Jul 20, 2009 | 1999 GMC Jimmy
Compressor not cycling on and off
unless the compresor is on u cant get a good eye on if ther is enough freon but still should cycle on and off/if it has a low side cut out switch (scews in the large line with two wires)that can be checked by bypassing the switch/but mind u it could still have a problem with ac system/and if the ac works when bypassed(very short run time)then replace switch with new one right away,also look for ac clutch relay and check or replace
Jun 30, 2009 | 2002 Dodge Durango
I cant open my bluetooth,and opened i cant recieve music files
your phone has a virus...
see your cellphone technician
Jun 19, 2009 | Nokia 6600
Ac does not work
sounds like moisture in system freezing up in the expansion valve. might recover 134. pull sys down and recharge. you know after thinking about this.
what about clutch cycle switch.
just some collective thinking
shack
Apr 18, 2009 | 1997 Mercury Villager
Location of low side ac port
the low side charging port is near the AC Accumulator/Reciever dryer cannister in the larger of the 2 AC lines.
Apr 07, 2009 | 1999 Ford Expedition
Ac clutch will not engage 1998 gmc sierra
sounds like low or no refridgerent in the system. start there. You can the cycle switch (low pressure switch on the side of the reciever dryer. the alumunium can on the left side of the engine in the back. You can also jump the two pins with a jumper wire and see if the compressure turns on then. Do not let it run for more than a min. you could burn up your compressor.
Good luck
Mar 21, 2009 | GMC G1500 Cars & Trucks
Vehicle Parts & Accessories Logo
Top Ac Delco Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Andrew Gaitan
Level 1 Expert
Terry Hair
Are you an Ac Delco Vehicle Part and Accessory Expert? Answer questions, earn points and help others
