Question about RIM BlackBerry Pearl 8100
I havea ultronic TD00552 I can't set. HELP
I have figured out mhow to set the time but hae been unable to figure out how to set the date.year ect. y pressing the reset on the back , Ican bring them up on the screen but can't get any further
    Problem Solver:
  • 15 Answers
Instruction manual
I havea ultronic TD00552 I can't set. HELP - a4188b96-023a-4ac1-ba80-ac425bb24aa2.jpg
Posted on Apr 21, 2014
  • Kurt Mathes Apr 21, 2014
    size limit also limited quality too much. sorry.
4 Suggested Answers
  • 3 Answers
SOURCE: ultronic lcd clock with a stylus tucked in back of clock
This thing set under my bed, lifeless til I was looking for something else and decided it was time to get this clock working!
(Use the stylus pen for best results) After putting in two fresh batteries (or hit the reset button if your batteries are fresh). This will reset the clock and the 'clock' icon in the upper lefthand corner will be blinking. Now press and hold the display area where the hour of the day is displayed. The entire time will start blinking. Now start tapping on the blinking hours to increment the clock slowly to the correct hours (it will cycle all the way thru military time and regular time, so choose what you desire). Press and hold with the stylus to increment quickly. Do the same with the minutes, that are blinking too. When time is correct, tap the 'clock' icon once. The 'clock' icon will still blink, which I believe is correct operation.
To set the date, tap on 3rd icon down from the top left (it looks like a little calendar). This will put you into the date section of the clock (if you do nothing, it will cycle back to the clock, after ten seconds, as a default). Before it cycles back to the clock, press and hold with the stylus pen right below the word 'DATE', until the the entire displayed date starts blinking. Tap the first two digits of the year to go down in years and tap the right two numbers of the year to go up in years. Tap on the month number to increment; do the same with the date number. When all date entries are correct, either tap the 'calendar' icon, or let the clock sit for ten seconds: it will cycle back to the clock.
I guess you can set the alarm in a similar method.
Hopes this helps!
ExitKC
Posted on Feb 28, 2009
SOURCE: Need instructions for a ULTRONIC WORLD TIME CALENDAR,
How to set the ULTRONIC WORLD TIME CALENDAR 01-22-2011
1. press the SET (MRC) key. The SECONDS in the lower right corner will start to blink
2. press again and the HOUR will start to blink. And again for the MINUTES, again for the YEAR, again for the MONTH, and again for the DAY DATE.
3. when you get the number you want to set, press the UP (M-) or DOWN (M+) ARROW key to adjust that number as you wish.
4. then press TIME to lock in that number.
5. repeat as needed to set the other numbers
Posted on Jan 22, 2011
SOURCE: setting an ultronic clock
Press "Mode" once to view the calendar
Press Mode again to view the alarm time
Set Time:
Press and hold Mode for 3 sec. to enter the time setting...Hour blinks..change by using Up or Down buttons. Press Mode again to set Minutes Press Mode to finish
Set Calendar:
Press Mode to see calendar
Press Mode for 3 sec to set year. Year appears, blinks...change with up or down buttons
Press Mode ..month appears...blinks. Change with up & down buttons. Repeat for day. Press Mode to finish
Posted on Mar 01, 2011
I have a ultronic TD00522 and can't set the date on it . Day,month and year.
Try Googling (ultronic)(TD00522)(manual) without parens to get instructions.
Nov 20, 2017 | The Office Equipment & Supplies
Setting an ultronic touch screen alarm clock
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
Jul 01, 2017 | Televison & Video
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 | Watches
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 | Watches
I can't figure out how to set the date.
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
Apr 26, 2010 | Fossil BQ9183 Wrist Watch
HOW SET THE DATE AND TIME FOR A "ULTRONIC " WORLD TIME CALENDAR
I have a ultronic TDoo552 clock that I cannot set. HELP
Sep 06, 2009 | RIM BlackBerry Pearl 8100
Need to set an Ultronic clock
Press the time (current time - numbers) to get to the date mode. Then hold-press "SET" to set it.
Feb 19, 2009 | RIM BlackBerry Pearl 8100
Feb 10, 2009 | RIM BlackBerry Pearl 8100
Setting an ultronic clock
Set Time:
Set Calendar:
Jun 14, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
1,933 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
