Motor cold sounds like a manifold gasket leaking but its not
I have 2001 Mazda Tribute V6 when the engine is cold and running sounds like a manifold leak but it not. I was told it could be the timing chain how can I find out what the noise is?
  • 3,320 Answers
Automotive question
Posted on Apr 01, 2014
Does anybody have a color coded vacuum / EGR hose diagram for a 2001 mazda tribute 3.0 LX
Matthew, Vacuum hose diagram should be under hood on a decal/label, on hood it self or on rad cradle usually. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ford Escape 3 0l V6 Engine Vacuum Leak Testing
Escape City Ford Escape Forums Ford Escape Mercury Mariner Mazda Tribute...
Remove Upper Intake Manifold 2002 Mazda Tribute Part 1 Detaching...
2001 mazda tribute 3 0 LX Detailed vacuum EGR hose routing diagram Google...
Jul 02, 2016 | Mazda Cars & Trucks
2002 Mazda Tribute ES V6 @ 65,750 miles. 1) I had two exhaust manifolds replaced (cracked) but still faint odor of exhaust in cabin. Mechanic cannot find leak. EGR failure? 2) While testing idle and...
Start the engine when cold day, block the exhaust pipe and you will find any leak.
Engine rattle could be valves, could be plastic body parts, could be air filter, could be ...
Aug 29, 2017 | 2002 Mazda Tribute
My 2001 Tribute has a very rough idle on cold start, and sometimes won't idle w/o manually using the accelerator.
Replace the gaskets on the intake manifold. My tribute was doing the same thing. Replace all spark plugs at the same time since the manifold is already off. They found small amounts of oil in my first 2 valves and plugs, but other 4 were dry. My car idles great and runs great now and it was a cold morning today!!! Also go ahead and replace the idle control valve if you like. I had to replace this first in the car with idle problems. Charge for replacing gaskets and plugs and cleaning it up in the cylinders.... $250.00 and it was well worth it! I have a side mechanic and do not go to dealers or other shops in town.
Dec 13, 2010 | 2001 Mazda Tribute
I have a Mazda Tribute 2001, and when the car is cold and i start the engine, the car started to shake, sometimes it turns off. It had a tune up, oil change, new injectors, and 2 sensors replaced. The...
replace all the "o" ring rubber seals for the intake manifold system. they leak when they are old and cold, until engine warms them up. the kit is cheap $20. the labour is going to cost more. this fixed my 01 tribute.
Oct 18, 2010 | 2001 Mazda Tribute
I have 2002 mazda tribute 3.0 v6. i smell exhaust inside when i am driving .could it be an exhaust leak or something?
Yes sounds like you have a exhaust leak check manifold gaskets. Untill you have this fixed u suggest you swith your blowers to recircultion to stop u from being poisened .
Oct 06, 2010 | 2002 Mazda Tribute
How to change spark plug on 02 mazda tribute
Is it a V6? For a V6 if you are standing in front of the car it will be the middle cylinder on the firewall side of the engine. You will have to remove the plastic engine cover and the intake manifold to get to it. If it were on the front side of the engine you would only have to remove the plastic cover. Since there is a good bit of work involved removing the manifold, I would suggest that you go ahead and replace all of the sparkplugs and consider replacing the coil for the one cylinder also. I have a 2001 Mazda Tribute. Mine started running rough so I decided to replace all the sparkplugs. After replacing the sparkplugs it continued to run rough. I took it to a shop and got it scanned (no cost for the scan). The scan showed the coil on the 3rd cylinder was bad. So I wound up having to pull the manifold off again to replace the coil :(
The first time it took me 1-1/2 hours to do the plugs, second time 1 hour to do the coil. Car runs great after coil replacement. Hope this helps.
Apr 28, 2010 | 2002 Mazda Tribute
2001 mazda tribute v6 runs rough cold ildes at about 200 rpm till it warms up then its ok what could it be
I replaced the upper & lower manifold runners seals, now it runs perfect, The reason it runs ok when warm is because the manifolds expand and seal the gaps on the surfaces that the worn old seals are not closing. Also change the spark plugs.
Jan 15, 2010 | 2001 Mazda Tribute
My '01 Tribute V6 3.0 has a rough idle at a cold start up, once the engine is warmed up and I have been driving for 5-10 minutes it clears up, but until then it will go dead if I do not give it gas at...
Don't waste your time. Have the intake manifold gaskets (upper and lower) replaced. Check all vacuum lines for leaks. Clamp all vacuum hose connections.
Do NOT replace any sensors unless the computer codes indicate.
THIS WILL FIX YOUR PROBLEM!
Oct 09, 2009 | 2001 Mazda Tribute
Problems with cold engine
It is the head gasket. Have that replaced and you will be fine. You have an air leak. I was told by the mechanic at mazda that the anti freeze eats away at the gaskets. CRAZY, but it works. I still have an issue with my 2001 Tribute revving while in park. Its always something.
Oct 24, 2008 | 2001 Mazda Tribute
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
