Question about AKG Audio Players & Recorders
C1000s hum/buzz on phantom power
My c1000s if connected with phantom power to my Apogee Duet makes a low hum/buzz. I've tried unplug everything and run on my laptop with battery and it happened anyway, so it isn't a ground loop problem... it's gotta be the mic right? Switch off the phantom and use the mic with a battery is perfect.
  • 5 more comments
  • Fabio
    Fabio Apr 25, 2014
    Hi Stefan, thanks so much for taking the time and help me out. As you say I think the energy is enough, especially considered that it exceed the energy the battery can supply, and the microphone is fine on a battery, no noise. So maybe the cable is good to? Is new, and is xlr both ends... maybe I should try a different cable before blaming the microphone though... I have this one from amazon:http://www.amazon.co.uk/Stagg-High-Quali... what do you think of it?
  • Stefan Mayrhofer
    Stefan Mayrhofer Apr 25, 2014
    Hi fabio. there is not much power to be delivered over the cable. It is by specification less than 10mAmps at 48V.
  • Stefan Mayrhofer
    Do you have a voltmeter? Check Pin 1-2 and Pin 3-2 for 30...48V each at the female XLR plug while your sound card is on and phantom activated. As you say the cable is new there should not be any broken wire inside. In this case the mic is to blame. I have the service documents here. First thing: Undo screw at the xor connector and gently pull out the connector. are the 2 wires ok? I would try another cable anyway and if possible another preamp. Just to ensure. The obvious things are checked and it sounds like something's wrong with the mic. Does the loudness change when you insert a battery?
  • Stefan Mayrhofer
    Further diagnostics is hard as I would need the microphone here to check the circuit. If you are experienced in electronics and say you want to try more I can tell you what to check on the mic's circuit board. best wishes & sorry for 3 posts but hitting "enter" will send the post instead of creating new line. cheers
  • Fabio
    Fabio Apr 25, 2014
    I've listened to some earlier recordings I made with the mic going through an analog Mackie mixer, and I actually recognised the same hum. I guess that at the time I just assumed it was something i had to live with, blaming the rest of the system, that was a bit hacky. I don't have a voltmeter, but I guess I could buy another cable from amazon, and if it hums again, I'll send the cable back. Then if it's the microphone I don't know, I guess I could open it but I'm afraid I could do more damage :-)
  • Stefan Mayrhofer
    Stefan Mayrhofer Apr 28, 2014
    Normally it does not hum. Maybe the best is to ask a local electronics to check the microphone. Sorry that I can't do more from here but the distance makes it way more difficult than it would be on my desk ^^
  • Fabio
    Fabio Apr 28, 2014
    Thanks Stefan, I'll try the cable first, I'll get a fender one, and then I'll move on from there. Thanks mate!
  • 40 Answers
Possibly the microphone needs more power than your sound card can supply although I cannot imagine as the duet is a good piece of equipment.
Is the duet USB bus powered?
Have you tried another cable? Possibly one wire is defective which means that phantom power will superpose the audio signal. In this case you might hear a hum. By the way this results in 6dB of signal loss. This is why XLR plugs have 3 wires. If connected with a 1/4" jack it has to be a stereo plug (tip, ring, sleeve)
Posted on Apr 24, 2014
  • Fabio
    Fabio Apr 25, 2014
    Hey Stefan, thanks so much for taking the time and help me out. As you say the power from the Duet should be enough, it exceeds the battery power with which the microphone is fine. So maybe the cable is to blame? I bought this on amazon:http://www.amazon.co.uk/Stagg-High-Quali... what do you think of it? is xlr both ends, it's new... maybe is not good enough to bring power and sound? When I put the battery in the microphone and switch off the phantom, the sound is clean... thanks
2 Suggested Answers
SOURCE: a buzzing sound
The cables always a usual suspect, but if you are using a tube mic, wich have their own power supply, you don't use phantom power and it can damage the mics power supply, so take phantom power off that mic and if that doesn't cure the buzz then I would change the cable next.
Posted on Aug 06, 2008
I have a kenwood vr-505 receiver that has a content buzzing through the speakers. I have unplugged everything and hooked it all back up but the buzzing still persists. Is it fixable?
is the buzzing constant frequency
or is it a hum like 50 or 60HZ mains
if its a buzzing like zzzxzxzxzzzzzzzzzz this is a bad connection in the mains and i would turn everything off
and get your supply checked out
Nov 30, 2014 | Kenwood Audio Players & Recorders
C1 not working
Sounds like your Phantom power supply may be defective. To be safe, 1st try moving AC plug for Phantom supply to another outlet as sometimes "sharing grounds" can be a problem. If this doesn't help, try using another phantom power source ...many PA mixers have built-in phantom power. If the buzz disappears with a new one, it will be a filtering issue (capacitors) with the old phantom supply.
Apr 19, 2014 | Behringer C-1 Microphone
Barely has any output. i thought it was low battery but it was not. what could the problem be?
If this is a (phantom) mic, it has to be plugged into a phantom plug on a mixer (round black thing with 3 metal posts in the middle. Darren Kelly-themasterofthrowdown@yahoo.com
Apr 28, 2011 | AKG C1000S Professional Microphone
I have a Focusrite Pro 10 i/o Firewire Interface and am experiencing 60 Hz hum through the mic pres when phantom power is switched on with the power supply attached. Phantom power running from 6-pin...
I assume you are using condenser mics as you would NOT be using phantom power with any other type connected or other devices plugged in while you have phantom power. It is important to have ALL interconnected equipment, including the computer, powered from the SAME receptacle or power source. Make sure the power supply you are using is SPECIFICALLY for the unit from Focusrite as some supplies have filtering within the wall transformer module and others do not. The power supply MAY be generating magnetic fields... try moving it around and see if hum is affected. The capcitive coupling in a power supply can let in higher frequency components from lamp dimmers. Make sure you have no lamp dimmers anywhere near the equipment.
Apr 25, 2011 | Focusrite Saffire Pro 26I/O 26 In/26 Out...
My tv makes a low humming buzzing sound about 3/4 of the time. One quarter of the time it does not buzz. When it buzzes a line moves fairly slowly from the bottom of the screen up to the top continually....
there is a bad or what i call intermittant connection on the power supply board. when the bar and hum appears try firmly bumping with the palm of your hand the side of the set. if the hum and line go away then your set will have to go into the tv shop and the connectors on the p/s mod have to be reseated also the solder connections should be checked... this should help you a lot.
Mar 09, 2010 | Maxent MX-32X3 32 in. HD-Ready LCD...
I have a low level hum in the MIC like a motorcyle in mt AT 4040
Remember this is a condenser mic that REQUIRES phantom power. There are several failures regarding this phantom power delivery that COULD cause your problem.
A "LEAKY" mic cable that is not a fully balanced cable can cause the problem. Test with another cable to exhonorate your cable.
A failure of the input bypass caps in your amp/preamp can cause the input to become unbalanced and let in hum.
A phantom power that is improperly filtered can also cause this. Test using a different source of phantom power.
Remember that you can easily get feedback that may oscillate like hum if you have a monitor speaker anywhere in "earshot" of the mic. They are very sensitive and intended for studio use.
Sep 26, 2009 | Audio Technica Audio-Technica AT4040...
A buzzing sound
Jul 18, 2008 | Electro-Harmonix EH-TM Microphone
148 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
