Question about Thule 2002 Ford Taurus - Sedan - Base Rack System
Need new rear struts
Our Taurus needs new rear struts we bought two quick struts like my uncle who is a mechanic told us now he says he can't replace them until he can find a blow torch. Everything I can find about replacing these says nothing about using a blow torch. What am I suppose to do.
How do I replace rear strut and spring
Replace it as a unit. Strut, spring, strut mount all in one. It's called a quick strut. Raise car by the body not the wheel. Remove brake line (1 bolt) from strut lower. Remove 2 large bolts holding lower strut end. In the trunk 3 smaller bolts hold the strut mount (upper end) in place. DO NOT remove the single large nut at the top of the strut assembly. Wiggle the strut assembly out. Slide the new strut assembly in bolt it back in. Put wheel back on. Done.
Dec 13, 2014 | 1999 Ford Taurus
How to fix rear shock springs on my car
the easiest way to replace the spring is to actually replace the spring and strut assembly together. most parts stores sell what they refer to as a "quick strut assembly". all you would do at that point is unbolt the old strut assembly and bolt the quick strut one on. no need to compress the spring to replace the strut etc. the process would involve removing the wheel, removing 4-5 bolts, removing the old assembly and then bolting the new one on. the complete assembly at autozone should run you about $130-140. good luck with it
May 26, 2013 | 1997 Chevrolet Cavalier
99 ford taurus rear tires wearing onthe inside.how do i fix
It sound like the Camber is off in the rear. Did you have an alignment done after the new struts wear installed?
Jan 03, 2013 | 1999 Ford Taurus
1999 ford taurus driver side back end lower had strut replaced in 08. can I still drive it
I think you have answered your own question. By asking, it shows that you are doubtful about it, and that is is really noticeable. That makes it Unroadworthy, and dangerous to drive. It will give poor road-holding and handling, and could cause a deadly accident. Better have that strut replaced again, and ask the Mechanic to find out what is causing these struts to wear out so quickly.
Mar 24, 2011 | Ford Taurus Cars & Trucks
Have had a cupping issue on the inside rear tires since I bought my 2004 Solara SLE new. Dealer says I have not rotated the tires frequently. That just delays the real issue. I am told struts and...
The dealer is right.Struts and bushings can have an effect on tires.Struts keep the tires in contact with the road,when the struts wear out,the tires start to bounce,but you may not notice it.I would start by having the struts checked and replace if need be.
Oct 06, 2010 | Toyota Solara Cars & Trucks
How to replace the rear springs and what size are brake lines.
rear springs are part of a strut assy, get a quick strut fom o'reilleys or az. it has the spring, strut, mount, all new and ready to pop in, otherwise you will need to tear the strut down and will need special tools. it is also a little risky, springs can fly pretty good when they slide out of compressors
Jul 07, 2010 | 1998 Ford Escort
How do you remove a rear strut from a 1995 ford taurus. i need to remove the strut from the coil spring
there is a tool to compress the spring.
you need to be very careful working on this job
you can get hurt very easy
Mar 07, 2010 | 1995 Ford Taurus
My granddaughter has a Ford Taurus which needs the strus replaced
shop rate labour is 2 hours and the struts are about a $100 each.
Mar 09, 2009 | 2003 Ford Taurus
I have a Ford Taurus 2003 SES that needs new front and rear strut
you will need sockets and a socket wrench, a screwdriver, jacks and jack stands, and a set of combination wrenches.
also this site should help, it's a very thorough step by step on strut removal
Jan 30, 2009 | 2003 Ford Taurus
Rear suspension noise
you should have rear struts with a leveling system and also strut mounts most likey its your strut mounts
Jul 21, 2008 | 1999 Cadillac DeVille
Thule 2002 Ford Taurus - Sedan - Base Rack System Logo
76 people viewed this question
Top Thule Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Thule Wine and Spirit Expert? Answer questions, earn points and help others
